LSI9 Troubleshoot, Tweeter
Patchouli
Patchouli Posts: 9
edited December 2017 in Speakers
Tweeter Dead in Left Speaker.
Swap Tweeters.
Play with RCA cables, L/R on amp.
Look at crossover. One badly burnt resister, one mildly burnt.
Order 2 new crossovers. Take speakers apart. Replace crossovers.
Swap Tweeters.
Swap L/R RCA cables into back of amplifier.
Swap speaker wires, connect L speaker output on amp to R speaker, connect R output on amp to L speaker.
While playing music all woofers are woofing.
Now what?
  • Note that I play music at lower volume at put my ear right next to each tweeter. It's not lower output it's dead.
    F1nut Posts: 51,763
    Bad internal wire or connection.
    Why order new crossovers when you could have simply replaced the resistors for considerably less money!!!
  • Patchouli
    Patchouli Posts: 9
    Because one was burnt so bad the board was literally fried and delaminated.
    Note on these speakers the wires are soldered onto the crossovers so changing the crossover also replaced every wire in the speaker.
    F1nut Posts: 51,763
    Ha, good reason.
    Are the jumpers in place and are they screwed down tight?
    tonyb Posts: 33,072
    Problem has to be with a faulty crossover. I know it's a pain, but swap crossovers, only way to know for sure.
    Tony M Posts: 11,617
    I HATE electrical problems !!! :s
