Two (2) RDO 194 tweeters needed.
daddyjt
Now that I have all the correct MW drivers (Thanks again Larry) for my CRS pair, it's on to the tweeters. I know I can get them from Polk, but I thought I'd check here first, in case someone is looking to unload a couple.
Thanks!
Thanks!
― Aleksandr Solzhenitsyn
PM for one anyway.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Ok, one down, one to go - thanks Ed!“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
