Schiit Vidar amplifier - internal wiring
Clipdat
Clipdat Posts: 13,100
Taking a look at the Schiit Vidar amplifier (http://www.schiit.com/products/vidar), specifically the internals, I'm trying to figure out why the wiring for the power input and speaker output terminals appears to be such a thin gauge. It looks like 18ga wiring, wouldn't at least 12ga make more sense for these type of connections?
I don't know why, but I get hung up when judging internals of electronics if I see something like this that looks like a weak point.
Thoughts?
    edited December 2017
    I've often wondered this for speakers as well now that you mention it. It seems the internal wiring on almost all speakers I've researched is also a thin ~18ga diameter.
    With the exception of the Bryston Mini A:
    DSkip wrote: »
    The role and gauge necessary for internal wiring is separate of that needed for external wire. This is true for components and speakers alike.
    SCompRacer Posts: 9,121
    18 gauge ampacity is 10 amps over 50 foot run.
    Well I guess that settles that. I apparently need to un-train my American public school system educated brain that "bigger=better".
    SCompRacer wrote: »
  • kharp1
    kharp1 Posts: 3,453
    It basically boils down to what value you want to have at any given point in the system. All pieces involved play a part. It's like voo-doo magic or sumpin...
    mhardy6647 Posts: 35,203
    heh, youse guyses peeked behind the curtain. You're not supposed to peek behind the curtain...
    In (some) seriousness, don't forget that the gauge of wire needed for a given job depends to a great extent on the current capability required -- and the current that will flow in a given circuit is determined by Ohm's law. For loudspeakers, impedance is low, voltage is relatively low, so high power equates to relatively high current. In car electronics (as such), the voltage is low, so current flow can be pretty effing high -- thus are the battery cables in cars pretty thick.
    It's also safe to say that Schiit hardware isn't a paragon of cost no object engineering. Quite the contrary, Schiit stuff is designed and built to be high value.
    Bottom line, though -- don't sweat the wires.
    Viking64 Posts: 7,617
    And don't wire the sweats.
