Ultra focus 8000 cable replacement
jflail2
jflail2 Posts: 2,868
Has anyone found a viable cable replacement option for the Polk Ultrafocus 8000s? I’ve got a pair I’ve been using at my desk for years, and I get an odd, staticky sound at times, which appears to be driven by the cable. Just opened up a brand new set for a work trip, and I’m getting the same thing with this brand new set.
I ask bc the stock cable has a bit off an odd shape on the headphone end, so I doubt just any cable will do. Any input would be greatly appreciated.
  • mrbiron
    mrbiron Posts: 5,721
    I would bet my left nut that the odd, static sound comes from your cellphone being too close to the headphones and/or source.
  • mrbiron
    edited December 2017
    Double Post Edited.
    VVVV Now it makes the one below me seem out of place :p
    Sorry Vik.
    Post edited by mrbiron on
    Viking64 Posts: 7,552
    ^^^^ Shouldn't the second post be for the right nut? :p
  • mrbiron
    Ooooo....double posts!
    Haven't had one of those in a while.
    My wife has laid claim to the "right" and i am not allowed to gamble with it without her consent.
  • jflail2
    Odd. I get it from both a direct connection to my phone, and my headphone amp on my desk. Regardless of source, it’s the same.
  • mrbiron
    When i have my phone on my desk, i get buzzing/static in my speakers right before an incoming phonecall, a text, and/or email. If the phone is pulled over a foot away, it doesn't happen.
    I'll let the more scientific guys explain that one. I just know it happens.
  • ALL212
    ALL212 Posts: 1,658
    The bigger question asks where your left nut is before an incoming phone call, text or email and if that is moved does it make a difference?
    Just asking...
    Aaron
    Enabler Extraordinaire
  • mrbiron
    Usually sleeping under my desk......slacker!
    I don't know what you mean by "moved"? That would imply that is moves on it's own and or someone moves it for me in which case, i should get on the cash grab train like rest of the country right now. ;)
  • Emlyn
    Emlyn Posts: 4,708
    The cable is 3.5 mm on the device end and 2.5 mm on the headphone jack end. It is a stereo cable except it also has the ability for a third signal to control or mute volume. The cable is flat to reduce tangles but as observed the 2.5 mm connector is proprietary. I would recommend contacting Polk to see if they can provide a replacement. There are 3.5mm to 2.5mm generic cables with return audio control but the shape of the connector is likely to be a problem on the 2.5mm end. The 3.5mm end is standard.
  • WLDock
    WLDock Posts: 3,073
    Polk should have them. I have the UF8000's, Buckle, and the Hinge headphones. I have ordered cables for the latter two from Polk.
    Call: 1.800.377.POLK (7655)
  • jflail2
    Thanks Emlyn. You're spot on with the odd shape/size for the can side, so I haven't found viable replacement as of yet.
    WLDock, these are actually fresh out of the box. Ordered a second pair a year or so ago on sale and tucked them away. Odd static/feedback right out of the box (including when my phone is several meters away from them and not connected), so I guess I'll just have to live with it.
  • jflail2
    To follow up here a few months later, I was on the train to NYC last week and decided I didn't want to listen to music, nor the people around me, so I put these on without the cable connected and turned on the noise cancelling. Turns out it's something in the headphones themselves, and is related to noise cancelling, as I received that buzz/static/feedback with no cable connected whatsoever.
    I think I'm going with the Sony NC bluetooth headphones as replacements. While expensive, they apparently don't have any issues with NC buzzing, and the blue tooth sounds rather handy.
