Are Yaqin integrated tube amps decent?
https://quadcities.craigslist.org/ele/d/yaqin-ms-30l-el34-integrated/6414481189.html
Seriously thinking about this ML 30 with EL 34s the price seems right and I'm asumming it should drive my CRS+s, or my 2bs thoughts anyone?
  • pitdogg2pitdogg2 Posts: 12,891
    Yes
  • DSkipDSkip Posts: 15,587
    $350 is a good entry price. If you've been wanting to try a tube amp that isn't a bad one for the money. You could do MUCH worse.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • ZLTFULZLTFUL Posts: 4,871
    The MS30L is a solid entry into the lighter powered EL34 world. It won't drop your jaw to the floor but it will do a good job of controlling smaller, less demanding speakers (or big high efficiency ones).
  • motorstereomotorstereo Posts: 1,109
    That seems like a very fair price. I have a Yaqin 100B and it seems to be fairly well made and has worked without issue the few years I've had it. I tried it on my 1.2tls a while back (all 60wpc) just for grins. It drove them yes; but tube amps on SDA's just aren't my cup of tea. Where'd that bass go and hide???
  • FaustinFaustin Posts: 851
    I second motorstereo.
  • I have the MC-30L on my 1.2TL's. Sounds great, plenty of bass. For that price it's definitely worth an audition.
    SDA SRS 1.2TL's w/ RD0198-1's, Sonicap, Mills
    AI-1 Dreadnought
    SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
    SDA 1C's stock
    SDA 2B TL's w/RD0198-1's
    SDA 2's (side by side tweeters) stock
    Yaqin MC-30L integrated tube amp
  • dhart86dhart86 Posts: 1,488
    Had one, liked it. 1st tube experience and drove all my polks speakers w/o any problem
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    PS Audio Directstream Jr Bridge II > Cayin TA 30 (buzzy-bee mods) >Monitor 5 (Westmassguy-modded)
  • teekay0007teekay0007 Posts: 2,087
    DSkip wrote: »
    Looks like he already dropped the price. It's down to $280!
    Go for it, Steve! You definitely need a new rabbit hole!
    That would concern me.
    audiothesis.com/
    Cabling: Wireworld
    Maybe there's local competition and he was priced a little too high.
    Just looked at the spec's. That thing really weighs 55 lbs?
  • Mikey081057Mikey081057 Posts: 6,105
    The KT88 based MC100B's can punch up a bit more bass for sure... Then with a tube upgrade... you can drive most anything.... I had mine with my 2.3's and it was sweet.
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7704 | Sunfire TGA-7401 | Oppo UDP 203 | Sony PS4 Pro| Directv Genie HD DVR | Samsung 75" Q8 QLED | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7002 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | PSAudio Stellar GCD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | Lumin U1 Mini | HP Elite Slice PC | ROON'd for life | Samsung 50" SUHD TV | Sony PS4
    Patio Polk Atrium 8's | Yamaha R-N303BL |
    Office Bluesound Node | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Chromecast Audio | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | 2 Parasound A23's | Marantz 2252B
    Just curious; I see you're using your description of the MC100B on your 2.3s in the past tense so I'm just wondering what amp did it replace and what amp replaced it?
  • teekay0007 wrote: »
    Yes, and the remote control is made out of solid aluminum.
    AI-1 Dreadnought
    SDA 1C's stock
  • ConradiclesConradicles Posts: 5,776
    I used one with my SDA 2.3TL's and it was a great combo. Hard to beat for the $.
    Right now the 2.3's and the Yaqin are "on the shelf" I use a Peachtree Nova 125SE in my office rig.
  • gudnoyezgudnoyez Posts: 6,734
    edited December 2017
    Passing on this deal, got two weekends of deer hunting starting tomorrow and as much as I would like to try this at this price it will cut into my beer spending money. I'm happy with my Vincent Preamp for now. Thanks all for all the advice I guess If I wait a while a better integrated tube amp will become available.
    I'm thinking you're going to have to wait a very long time to find a deal that'll better that one. I wouldn't be surprised if it's long gone anyways and the seller hasn't gotten around to taking the ad down.
    Hey I'm already upset about passing on this one at this price if it's still available Sunday night when I get back I might give it a shot. If anyone is interested in this and close to the Quad Cities I would be more than happy to get it hold it and meet at a half way point.
  • mikeyb128mikeyb128 Posts: 2,823
    gudnoyez wrote: »
    You must have a huge beer budget. Especially living in America. You should try buying beer in Canada.
    2 channel:
    Theater:
    gudnoyez wrote: »
    Excuses; A quick story about how I picked up my Yaqin. I had just gotten laid off from work that week when I found a fair deal on a 2nd Mac mc2500 halfway across the continent. I was terribly disappointed when the seller decided the 129lb amp was too much to ship. So I find my Yaqin locally as a consolation unit; buy it and I'm in the car with it when I get a text from the seller of the 2500. He's changed his mind now and will ship it after all. Sooo with no job, near Christmas and budget beyond stretched thin I went for it and still have both units. I had plenty of excuses to and I'm glad now that I didn't use them :) .
  • mhardy6647mhardy6647 Posts: 21,248
    mikeyb128 wrote: »
    gudnoyez wrote: »
    Wait, what? You don't have socialized beer in Canada?
    (I'm sorry -- I couldn't resist!)
  • Viking64Viking64 Posts: 3,784
    I've had a lot of ANTI-SOCIAL beer in Canada. B)
    DSkip wrote: »
    Wow. Fantastic deal!
    AI-1 Dreadnought
    SDA 1C's stock
    It's sold I don't feel bad now that I hesitated, it was a great deal someone got. The Vincent Preamp, and the Vincent phono stage will still be in the 2 channel if it was not the holidays and hunting season, I would of got it the minute it posted.
Howdy, Stranger!
