OLED vs. QLED - My Observations
245
  • DSkipDSkip Posts: 16,115
    Not long before. They knew it was on the horizon.
  • pitdogg2pitdogg2 Posts: 14,317
    edited December 2017
    DSkip wrote: »
    I'm speaking more about current tech TV's. Refresh rate has been stuck for a while.
    Plasmas died out when 4k hit the market. My gut always told me that they couldn't efficiently compete at that resolution and so the technology died.
    They could pretty sure but the mandate to use less energy killed them. My Panasonic could really warm up a room. You could feel the heat off it when you stood within 2 feet of it.
    gmcman wrote: »
    DSkip wrote: »
    Maybe there is a hard limit that they can't get past?
    I think its called the EPA.... :*
    Don't think my plasma ever received the big energy star sticker.... B)
    No and that is why there are no more Plasma's. They could not meet the new energy rating for TV's.
    Plasma's to my eye's looked more like film more natural
  • rpf65rpf65 Posts: 2,056
    Not only that stupid energy star sticker, but cost.
    Getting plasma to 4K resolution would have priced them out of the market. Panny was saying it would be $8k to $10k for a 50 inch set. They didn't see a market for them.
    rpf65 wrote: »
    That was my point. Thanks. It would be great to see it come back but I think OLED is the wave right now. Black levels are great and all but I still value that refresh rate above all else.
  • EmlynEmlyn Posts: 2,472
    My 42 inch 1080p Panasonic plasma set is rated at 575 watts while my 65 inch Sony LED 4K set is rated at 285 watts power consumption. The LED set also weighs less and cost about the same originally. The plasma set also suffers from temporary image retention. Motion and contrast are better and more lifelike on plasma over LED, although the differences have narrowed a lot. If a 65 inch plasma coukd do 4k, the power consumption would be horrible. The image would be spectacular though!
    Plasma left the market because people stopped buying them in favor of something more suitable for everyday use at home.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Sonic Frontiers Line 3 Preamp; Classe Model 25 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio Power Director; MIT S1 Cables
    3. Polk LSiM703; Parasound JC2BP and A21; Sony 48" 4K TV; Wyred4Sound DAC 2; Oppo 203; Squeezebox Touch; MIT S3 cables
  • Viking64Viking64 Posts: 4,250
    It's nice having a TV that's too heavy for someone to steal. :p
  • BlueFoxBlueFox Posts: 12,050
    Viking64 wrote: »
    Bring back the CRT RPTV. :)
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
  • FestYboyFestYboy Posts: 3,699
    What's refresh rate matter when most media is at 24 or 30 fps(Hz)??
  • txcoastal1txcoastal1 Posts: 10,584
    A lot of sports are now available at up to 60fps
    Why have a 400 watt amp :/ B) ...Headroom
    Ok so 60 fps native, I get that. But now we're at 1:1. There's no such thing in the realm of audio signal as it is truly dynamic, where a tv is a fast cycling still picture...
    FestYboy wrote: »
    Really????
    Some sets it is not unusual to see the white trail behind a hit baseball. And forget car racing it gets all blocky and pixelated in the corners and the crowd above. Never a problem with my plasma.
    So what exactly is happening there? Latency? Poor post processing?
  • Even though the plasma can refresh at 600hz the image is still only displaying 24fps or 60fps depending on the source. It’s just repeating frames. Some 120/240hz sets with motion technology in led/lcd try to predict and create frames rather than repeat them. Most of time the result is very unnatural and should be turned off. 24fps is considered filmed and is still ideal for movies. Sports are considered video broadcasts which video is 60fps.
    ^ exactly what I'm getting at... What's the point of extreme refresh rates if 1:1 is superior?
  • tonybtonyb Posts: 31,440
    FestYboy wrote: »
    Really????
    You must be looking at cheap sets then. Everything with motion is about the processor. Just like a slow processor in a computer. Sony and Samsung have the best processors in my opinion. Pixelation and other junk simply doesn't happen on the better sets displaying a HD signal.
    Where even the good sets start getting wonky is when they try displaying a non HD signal. Personally, if it's not in HD, I don't bother watching it.
    B&k 1430
    Tad 803 speakers
    tonyb wrote: »
    FestYboy wrote: »
    Really????
    Nope everyone's eyes are different. Even though i wear glasses. When i look at DLP stuff as i scan across the screen i see little rainbows of color out of the corner of my eye's. Look it up its an artifact some people see. Same with LCD for me i see blur trails on some. True upper sets are much less but i still see them on some. Once you see it you cannot unsee them. Like a too bright set it gets fatiguing.
    That's called an uncalibrated set then Ivan. Especially if it's a store display. Newer sets have a display mode that makes them run hot so they pop. You don't really think Timmy at BestBuy, who doesn't even know he works there, is actually skilled at calibrating sets.
    B&k 1430
    Tad 803 speakers
    Tony i know all about calibration. Yes i spent good money for it to be done on my pany plasma. That sets color kelvin rating to be more in line with the standard as well as gray scale.
    Yes i agree they set them to torch mode for stores
  • Airplay355Airplay355 Posts: 4,294
    I recently moved to a Sony 900E. I've got the brightness on 16/100 and I still watch with a dim light on in the background. I could have spent $500 more and gotten an OLED but I didn't feel like I needed that much TV. The Sony got me 90% there, at least as far as I can tell. 4k content is nuts. I thought the QLED TVs were overpriced.
  • Mr_HzMr_Hz Posts: 173
    I haven't contributed to the conversation since I threw out my initial salvo... but appreciate all the perspectives/input/opinions. Its made for a lively thread!
    Still happy with my Panny Plasmas... but one day I must move on... I've staved off 4K upgrades for ~1year.. me thinks 2018 won't bring any reason to join the 4K crowd yet.
    Even with the 'in-house display surprise' between OLED & QLED fundamentally I know Organic should be the better technology by all the specs and science behind the technology. Too much $$ invested in normal DVD's and BlueRays that look (sufficiently) great in 1080p and 1080i to worry about the expense and choices of 4K for now.
    I gots Italian cars (Alfa Romeo) to take care of. Long live my plasma sets! lol
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
  • I also am on the fence about upgrading to 4K. If I do, it would be OLED. QLED, to me is just another version of an LED.
    Here is my concern with the best OLEDS - The screen producing the sound (as opposed to separate/attached speakers) might be cool to some people. But to me, it's something to be concerned about. What if the sound built into the screen craps out. Maybe it might even cause some other unforeseen problem with the tv as a whole.
    For now, despite all my questions on the forum, I'm standing pat, and won't be making any changes to my ht setup.
    Would probably go LED if I upgraded. Still have concerns about longevity. Last I checked, it was said, that the blue pixels have a10k life span. Figure half that.
    Does any consumer product made today have a lifespan of older products ? Seriously guys, your splitting hairs. You are not going to get a lifespan in consumer electronics these days from anything. Some technologies may be worse than others, but as a whole, they all suck.
    LED has been around for a while now and most the bugs have been worked out, it is what it is these days. Oled is still fairly new, so if I was to buy one, an extended warranty wouldn't be a bad idea.
    B&k 1430
    Tad 803 speakers
  • K_MK_M Posts: 1,396
    OLED :)
    Plasma :)
    LCD (QLED, LED) :#
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4,SDA 3.1TL, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-Sold
    Epos-Now gone
    Infinity-Sold
    Advent-Now gone
    Yamaha A-S801
    Yamaha RX-V377
    Yamaha RX-A860
    Yamaha RX-A3060
    Harman Kardon Hk-350i
    Harman Kardon Hk-........
    Harman Kardon PM-665
    Harman Kardon HK-775
    Pioneer.......Stereo Receiver
  • mrbironmrbiron Posts: 5,124
    tonyb wrote: »
    Items would last longer, but what is easier to do in today's society?
    A-Pay the high repair costs
    B-Throw away and buy new
    C-Try and repair it yourself
    I'm all for "C", but there are scenarios that are beyond ones capabilities ie. dead pixels.
    I repaired, a couple of years ago, a TV i bought new in 07. 4 replacement caps cost me $10. She's still my daily driver. Only when i CAN'T repair it will i think about getting a new one.
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Crack w/Speedball, Senn's MD HD600
    If dead pixels are a concern then, Oled is more prone do it than LED. Most are not up to the task of TV repairs themselves and the cost to outsource those repairs negates the cost of the TV in a lot of cases. So yeah, depending....they are throw aways. Most consumer electronics are these days.
    B&k 1430
    Tad 803 speakers
  • mhardy6647mhardy6647 Posts: 22,990
    mrbiron wrote: »
    tonyb wrote: »
    I think you can buy jars of bulk-packed pixels on eBAY...
    Someone needs to buy a bag of 500 and then sort them into bags of 50 and give them out as karma. :p
  • deronb1deronb1 Posts: 4,758
    mrbiron wrote: »
    tonyb wrote: »
    Next to the liquid squelch, above the left handed shelf stretchers.
Howdy, Stranger!
