New Parasound 2250 or Used McCormack DNA-1?
I've heard great things about the McCormack DNA-1, but it sounds like Steve McCormack is not servicing or upgrading them anymore. Any thoughts out there on a clean but well-used DNA-1 (the original model, not the Deluxe or Rev 1) versus a new Parasound 2250?
  • hochpt21
    hochpt21 Posts: 5,423
    The DNA 0.5 bested the HCA 1500a in my system if that helps at all.
    cheeg wrote: »
    SMC works on McCormack amps, and also Conrad Johnson, since they bought 'em up.
    I'd personally take a McCormack over a Parasound any day, and that's not a dig on Parasound as they have fine amps themselves. The McCormacks are simply better.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited December 2017
    McCormack all the way for me though as I have posted previously I've not heard the Parasound.
    I think Conrad Johnson bought out the McCormack brand - Conrad Johson used to servcice them as well as Steve did at SMC. CJ may have stopped, not sure, but I as far as I'm aware SMC has been working on these amps at least very recently. I have one that was upgraded just last year, and another Polkie just received his back in the last month or two as I recalI,
    I have the DNA-1 Standard, and it is no slouch whatsoever. I'm sure the upgrades are worth it, but I can say you are unlikely to know what you're missing until you hear them. A fantastic amp.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • cheeg
    cheeg Posts: 11
    Thank you all for your responses! A follow-up question: if SMC and Conrad Johnson is no longer servicing them, as MrBuhl suggests, is there a reliable alternative short of an expensive upgrade?
  • gmcman
    gmcman Posts: 1,858
    cheeg wrote: »
    I don't believe Mr Buhl wasn't suggesting Steve wasn't working on the amps, just not at the CJ location.
    I just received my DNA-1 back from SMC, they performed a Platinum Ultra upgrade. I would say you are safe.
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ Correct - sorry for any confusion ^^
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
