Cement pond progress...
steveinaz
steveinaz Posts: 19,546
edited November 2017 in The Clubhouse
Excavation, plumbing, electrical, and equipment in place, rebar is next:
The tan sleeve in the pump pic is a place-keeper for the saltwater chlorine generator cell. The "loop" in the PVC at the clean water return of the pump, is for future addition of solar if we decide to go that route; "solar ready" so-to-speak.
    msg Posts: 10,458
    Coming along!
    Post edited by msg on
  • MrBuhl
    MrBuhl Posts: 2,419
    ahh - I miss the days of pool building... not really. But that's coming along nicely!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    Tony M Posts: 11,680
    looking good !
    F1nut Posts: 51,943
    Has the wall been repaired?
  • steveinaz
    Not yet. When the wall guy comes to raise some areas (pool code) they'll fix it. In Arizona, your wall can be your primary barrier, but it has to be 5ft minimum height, non-climbable. Any gates with direct access to the pool have to meet the same standard and be self-closing/latching.
