Why do Polk speakers get no respect?
Robpar
Robpar Posts: 8
edited November 2017 in Speakers
Why is it that in just about every review I read, Polks don't get excellent reviews? are the really that much worse than say... Def Tech, B&W, MartinLogan, Klipsch
I have Rti12's and "everybody" says they sound bad for music.
Would I really get that much of an improvement if I went with MartinLogan's Motion 60Xt or Sierra 2 towers or Aperion Grand Verus II or Klipsch RF 7 II?
Even the new Polk LSi don't get a great review.... (also considering the LSI 707 since they are on sale now)
  • I too have the 12's and while I don't agree that they sound bad, by any means, for music. I would agree with people that something like vintage monitors or SDA's sound much better. If you're looking for something to get into music, you can't go wrong with the vintage monitors or SDAs. Having came from the 12's to the SDA's (CRS+ and 1C) and monitor 10b's, I'd say you wouldn't regret it.
  • Having came from the 12's to the SDA's (CRS+ and 1C) and monitor 10b's, I'd say you wouldn't regret it.
    Can you clarify: CRS, 1C and 10b's; what are they?
  • mrloren
    mrloren Posts: 2,474
    RTi are great for HT use, for music they are not bad once the source in set correctly. Big thing about the RTi line is they like a lot of power to sound their best.
  • Robpar wrote: »
    I currently have all of the above, the 10b's are in my office setup the 1c's and crs are on rotation in the "sda room"
  • Upstatemax
    Upstatemax Posts: 2,735
    One of the problems for Polk, in general, is a lot of their speakers like power to sound their best.
    That usually flies in the face of a budget minded consumer (MOST Polk customers). Power, usually, cost money. So, a lot of Polk speakers are underpowered and suffer sonically because of it.
    I firmly believe if Polk stopped trying to make their speakers play so low and make them better balanced they would do far better. Once you introduce POWER or a sub so that they don't have to play so low they do much, much better.
    A GREAT example of this, IMO, is the Polk S20's. On a pretty typical receiver that would be used with this speaker they sounded bloated and unbalanced. I'm currently borrowing a 200wpc amp from a friend and they sound much more balanced and controlled. Still a bit too bloated in the bottom end for me, but better. If Polk just tuned this speaker to a more realistic frequency response, it would be a MUCH better speaker.
    Naturally, this is all just my opinion...
  • Get your learn on SDAs especially the 4th and 5th generation are very desirable. You will not find at any price a speaker that does what they do
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Robpar wrote: »
    Do you think your RTi12s sound bad for music?
  • mrloren
    Upstatemax wrote: »
    I agree that Polk's like power... My S20 are driven by a Marantz SR5010 and sound great on both HT and music. My S60 were on the same AVR and sounded good. I added a small Emotiva amp and they sound even better.
  • Robpar wrote: »
    I like how they sound at higher volumes (80-85db's) but at mid or lower level volumes they sound dead. They are powered by Parasound 2250 (275W/channel)
    Using a NAD C375BEE as pre-amp (it also drives smaller ceiling speakers)
    So, I am just wondering if an upgrade is worth it
  • SDAs, you won't regret it.
    tonyb Posts: 33,068
    Robpar wrote: »
    Robpar wrote: »
    If they sound flat at lower volumes, your problem is probably a impedance mismatch along the lines.
  • I like how they sound at higher volumes (80-85db's) but at mid or lower level volumes they sound dead. They are powered by Parasound 2250 (275W/channel)
    So, I am just wondering if an upgrade is worth it[/quote]
    I agree about the 12s, no impedance mismatch here and feel the same way. They just don't come alive until they're too loud. OTOH any variety of my vintage Polks seem to be alive and well even with the knob cracked open. IDK.
    tonyb Posts: 33,068
    How do you know there is no impedance mismatch ? Cables can have it, gear can have it. What's the voltage output on the Nad and whats the input voltage on the parasound.
  • Because I've seen many comments regarding the same thing about 12s not coming alive until they're too loud and don't sound balanced. I've used the same equipment with my older polks with great results. I have trust that the quality control of the equipment. Better question for you might be do you think everyone that has 12s and thinks they sound flat until you turn them up has an impedance mismatch? I believe it's simple to try to analyze everything but the problem, the 12s.
  • I try not to buy speakers so they can be respected, I tend to buy them for how they sound.
    pitdogg2 Posts: 26,961
    Might be why polk decided to revamp the XO and cabinet and call them RTia9....
  • There’s nothing wrong with the 12’s they are a great speaker. They have a very flat/accurate response though and at low volume can sound sterile. Musical speakers tend to have extended highs and lows to some degree so they will sound more dynamic at lower volume, but are not as true to the source recording. Keep in mind reference levels are quite loud and are where the RTI are meant to perform their best. Makes them fantastic for HT but low level music, not so much.
    Toolfan66 Posts: 17,998
    Not sure what anyone expects from the Rti line for music, they are fantastic for movies, kinda what they were made for were they not?
    The LSiM sound great for music IMO, and with the 50% off sale makes them hard to beat...
  • Toolfan66 wrote: »
    Well, that's why I posted originally; to see if there is an upgrade that is worthwhile. LMsi? (now that they are on sale) or go to next level price point...say $2,000 a pair? Aperion towers? Sierra towers?
  • rpf65
    rpf65 Posts: 2,127
    Wouldn't really say the Aperion's are necessarily better than the LSI M line, just different.
    I really liked the RTI A5's for HT, but after listening to them for music began hearing things I didn't like for music. Adding power, cables, and generally everything else advised here to improve sound, I finally came to the conclusion that the RTI A line wasn't what I was looking for, at least for music. Nothing wrong with that.
    Bought the LSI M705's, and after playing them for about a week, felt these were great speakers for music. They only got better as they broke in. Recently pulled the A5's out, and watched a movie, half of it through the A5's and half through the 705's. I think the A5's did a much better job. So I think Polk got both lines right.
    There are a couple of manufacturers that offer a product range that is huge, in price. Doesn't matter if it's one of there $500 or $5000 products, I don't like them for music. More people would think I'm nuts than agree with my opinion, but that doesn't really matter. My opinion is important and theirs is meaningless.
    To use your example of Aperion, Polk probably sells at least 100 times the speakers, all lines together. Simply cost Polk less to manufacture that LSI series speaker than it cost Aperion to manufacture their Sierra speaker. So I would say the build quality is about the same. The sound will be different, but one sounding better than the other is still an individual's opinion.
