Looking at doing a second tube amp build...
nooshinjohn
I am thinking of doing another tube amp build after the holidays, and going BIG once again. They will be based off of my previous build but have 4 pairs of KT120’s (8 power tubes) instead of 6. There will be no granite harmed in the construction of the new set, but I will be looking to embellish them with a level of quality to go along with the performance.
This set is still in the very early stages of planning, but it should be a fun project.
Is Bob Carver going to be involved with the new set ?Most people just listen to music and watch movies. I EXPERIENCE them.
I don’t think so, at least to the level he was the first time. I will be asking questions for sure. I will be working from basically the same basic schematic, but adding the needed changes for then second pair of tubes. I will also be installing meters on the front of these this time, and using larger power caps.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Why not base them off those newer power tubes or would you need a whole new ground up design?
What tube are you talking about?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I could use those as well...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
watch the video I didn't know that the Russians were not doing their due diligence. Prima Luna basically states the same on their site.
Been searching for inspiration for the new build, and so far I am drawing a blank on it. I love the look and feel of my current amps so much that I feel they will be hard to beat. I am thinking of going after a 1930’s Art Deco feel for them and perhaps taking some design cues from Ettore Bugatti, and Gordon Buerig...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
If the appearance is what you are trying to decide then forget other designs. Do your own thoughts, but definitely make sure the electronics are 100%.
Three 20 amp circuits. -
Found it... don't have a clue on the meters yet, but I like the look.
Just to update... I have finalized the look I am going for on these new amps, and granite is back on the table, but will be used on the front and sides instead of on top. The middle will be set with a large VU meter set behind silver toned smoked glass. I should be able to start posting some pictures sometime in September.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
This just an aesthetics upgrade using the same schematics as last time, or a total redesign inside and out?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
A small redesignThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
LOL... My original amps are performing very well 7 years later, but I have the itch to upgrade, and can't afford to buy anything that comes even close to what I have now.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
You gonna snag your transformers from Bob again?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
No... Bob gets his from the same place I will be sourcing mine, and they will be the same ones used as last time.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Interested, looking forward to seeing it.
Best of luck, but I know you will do an awesome job.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Reach out to Robert at Star Sound Technology and tell him I referred you. Tell him what you are doing and he might be able to help you make the chassis and construction work for you instead of against you. He is not a circuit guy but he understands vibrations and resonance.
I have absolutely zero vibration now, and the new chassis will be more robust than the first amps. Thanks for the lead. I may give him a call, but I don't think there will be much he can offer that has not already been considered.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »LOL... My original amps are performing very well 7 years later, but I have the itch to upgrade, and can't afford to buy anything that comes even close to what I have now.
Yup, that's why I DIY/scrounge. Dollar for dollar, it's the way to go if one can do it, as far as I am concerned.
PS Your "A small redesign" comment just, for some reason, put me in mind of that Shawn Colvin album title
Absolutely no logic operating on my part at all!
The small redesign is basically cosmetic, and the addition of two more power tubes per channelThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
An update... I have decided to go with a twin chassis monoblock layout, separating the power section from the output section. It will still be 8 power tubes, but the new chassis will allow me to locate the bias/output meter and the 12ax7, 12att and the 6al7 to the new chassis and give a better look to the whole. Granite will again be used, but will be a blue pearl color this time with midnight blue transformer covers and satin nickel trim.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Dibs on the old stuff! JK. I'd never be able to afford it...Gustard X26 Pro DAC
How so?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
My current amps are made with granite as well and are anything but cold and sterile....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Doesn't high-end amp sellers place their tube amps on elevated granite stands?Most people just listen to music and watch movies. I EXPERIENCE them.
You have no idea what those amps are capable of. I'm sure they are fine as is, but why settle for 'fine'?
I built them but I have know idea what they are capable of? You have never been in the room with them, never heard them, and are going to tell me that I am wrong or missing something?
Excuse me while I have a good laugh....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Granite is very ring-y.
It's consequently a lousy turntable plinth material.
How that would translate to an amplifier is unknown to me; certainly could be a problem with any tubes prone to microphonics, though, I would think.
Try mounting them on a 2" thick rug of beaver fur. THAT would be awesome!Gustard X26 Pro DAC
Your arrogance is absurd John. Forgive me for trying to actually elevate your experience. Keep thinking you know it all. I don’t have to hear your amps to know there is massive potential being left on the table.
I like you Skip and have nothing against you, but would it not also be ignorance to assume you know more about what I have built than I do? And then rather than shoot me a pm or something to discuss, you then show your emergent arrogance by basically calling me a fool in my own thread? This was done to me back in the original thread I had when I started the first build back before you had a clue what high end audio was.
I am proud of you and what you have accomplished in such a short span of time... I truly am. What I build, I build for me and nobody else, so if I am getting all of what I want from it, who bloody cares.
