I moved reconnected my MagnFi sound bar, no sound.
Hi, I am new to the forum and not great with tech. I moved and then reconnected my soundbar to same tv. But Dish network now. I went to the menu and found settings, sound and placed it outside speakers from tv speakers and now I have no sound from speakers or tv, help!
Answers
    Viking64 Posts: 7,614
    klyball wrote: »
    You might want to try posting this in the "Troubleshooting" section. You also might find a solution to your problem there.
  • Hello,
    As a test try connecting a digital audio cable (should have come with your bar) directly to the satellite dish receiver's digital output. Make sure the satellite dish receiver is set to Dolby Surround setting. Also make sure your bar is set to the correct input.
