Power conditioners.
I do not, and never have, used a power conditioner. Are they worth the investment? I've seen a lot of them listed on eBay, and that makes me think I might be able to snag a good deal while also wondering 'why are people ditching these'?
    pitdogg2 Posts: 27,249
    edited November 2017
    Last place I'd buy one..... Do you know if they have taken a good hit? Nope
    They right ones are worth their weight in gold, others not so much.
    I'd only buy use if i knew you real well.
  • I don't know. You have to wonder how often these things get stressed with a voltage spike.
  • mrloren
    mrloren Posts: 2,474
    one thing to look at, how much $$$$$ do you have is your gear. What part of the country do you live in? Are there are thunderstorms in your area? If yes, then a good power conditioner/surge protector is a must. I don't know how many times I've seen people hooking up $1.000 TV and $2k in audio to a Costco $10 Cyberlync surge protector.
    My mom lives in Oklahoma, Everything in her house is plugged into these
    https://www.amazon.com/gp/product/B0002YDZWO/ref=ox_sc_sfl_title_12?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
    She has yet to have anything fry so I got one to try. Yes the picture did get a little cleaner on my TV and maybe a little help on my audio.
  • kharp1
    kharp1 Posts: 3,453
    Kind of depends on what you're wanting it to do. Do you want true power conditioning? Or, are you just looking for equipment protection? Some designed just for protection can actually degrade your SQ.
    As mentioned, beware of used unless you know its history.
    F1nut Posts: 51,961
    Real power conditioning/surge protection costs money. Look at products from PS Audio, Shunyata and SurgeX, all proven to be worth the coin.
    Another thing, power amps should be plugged directly into the wall.
  • I have a Furman Elite-15 PFi power conditioner and I've been quite happy with it. It also has 45 amps of AC power reserve which improved my amps performance and sound when compared to being plugged into the wall or my old Panamax 5100 which is now in my garage.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • [quote="F1nut;
    Another thing, power amps should be plugged directly into the wall.[/quote]
    Why is that? Do conditioners restrict current?
    Yes some do restrict current. Many amps also have power conditioning type of device just past the incoming power cord, not all but some. 20 amp circuits and wire do not impede the juice your amp wants to pull.
  • kharp1
    kharp1 Posts: 3,453
    I have the Ps Power Plant 3 and I use the amp circuit on it and am happy with the results. Some can restrict peak current.
  • Joey_V
    Joey_V Posts: 8,603
    I have a P5, I cannot figure out (possibly because I am short on time), which combination of electronics plugged into it yield the best sound. Right now I am testing out the amp and preamp into the wall, while the Emm Transport and Emm DAC into the P5.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    I use a Silver Circle Audio Pure Power One 5.0 power conditioner in my main system and plug all components into it -- CAT 600.2 amp, PS Audio DirectStream DAC and PerfectWave Transport, MacIntosh C220 tube pre.
    Before I installed the power conditioner, I had a lot of noise in the background. After installing it, the background is black.
    As others have said, good power conditioning is expensive, but it is worth every penny in SQ improvement, in my opinion.
