SRS 2.3TL
pelhamplace
First post -- I have been reading the site for over a year. There are incredibly knowledgeable people on the site; very intimidating. I have a pair of SDA 2Bs (unmodified). I have an opportunity to buy a pair of SRS 2.3TLs. I would like to do all the necessary mods using the information available on this site. I figure that if I'm going to do all the mods it makes more sense to step up to the SRS 2.3s. Am I on the right track?
Best Answers
2.3TL's have the potential to be the last speaker you will ever buy once they are upgraded. I would not hesitate if you can get your hands on a pair.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
^ What he said ^Political Correctness'.........defined
President of Club Polk -
The 2.3 tl's are probably one of Polk's best speakers they ever put out. Like John said, once upgraded, you'd be hard pressed to do better for the money. Grab 'em, update 'em, and enjoy.HT SYSTEM-
Answers
Thanks for the input. Hopefully I can pick them up this weekend!!
My First post as well...Happened to check the local kijiji and came across a pair of SRS 2.3TL's for $200 Canadian...which is what about 160 USD!!. Had to replace a couple of the midrange drivers but what a steal easily the best speakers Ive ever had. No mods as of yet but a recap is in the future plans.
Andrew
Kamloops, BC, Canada -
Andrew
Pictures or it didn't happen is the rule here
Welcome to club Polk -
I love mine. They are great speakers. Go get them.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Andrew
Congrats and welcome to the forum. -
What would be the first and least expensive mod to do ?
Thanks in advance
Andrew -
Reseal the cabinets if needed,glue the magnets and dynamat the baskets.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Thank you dkfreebird!! Specifically which type of glue and are there any images on the site to follow.
Cheers -
Loctite power grab and if you search 2.3tl upgrades you should see several posts on them.2 Channel
Oppo 103
Pangea PC
SDA's of this size are supposed to be 3 feet from the outside walls. Although I can't see much of the wall behind your gear and just how long it is, it would probably help a lot if you shifted things to the right a bit. Perhaps switching the right cabinet and the subwoofer.
I used Loctite brand PowerGrab Express as it can be used for both sealing the cabinets and gluing the driver magnets. Two tubes should be more than enough. You should get the 6oz squeeze tube as opposed to the 9oz tube that is used with a caulk gun because there are so many nooks and crannies you'll need to get inside the cabinet where a caulk gun won't fit.
https://www.homedepot.com/p/Loctite-6-fl-oz-Power-Grab-Express-All-Purpose-Construction-Adhesive-Squeeze-Tube-2029846/206432100 -
Yea unfortunatly this placement is temporary Im building an AV room upstairs in the attic but again won't have the space to do the 3 foot spacing from the walls and 6-8 feet between the speakers; the new AV room is 11X22. They still sound amazing as is but I will switch around the subwoofer and I am presently running a Yamaha M4 amp with an Anthem Tube Pre amp (PRE2L). I'll check the local home depot they should have that brand. Thanks to all for the information what a great resource.
Andrew -
From the images where exactly am I installing the glue?
Andrew -
Ha Im have trouble loading images !!
Where the magnet meets the metal.2 Channel
Oppo 103
Pangea PC
Yeah, the site was acting weird for a few minutes. I shopped one of your images but I couldn't upload it.Ha Im have trouble loading images !!
Thanks again guys its now of course obvious where the glue has to go...
Andrew -
Dynamat extream the baskets while out.
Rabbit is fully opened
