Looking for a high temp pipe coupling
Not audio related at all, but can anybody point me to a 6" diameter fernco type coupling that can withstand 500 degrees F?
Yep, my name really is Bob.
  • FestYboy
    FestYboy Posts: 3,861
    500!?! Dear God man, what are you up to??
    To answer your question, look for a silicone coupler ment for automotive intake piping. There are a few companies that will build you one to spec, though 6" might be a bit pricey.
  • muncybob
    muncybob Posts: 3,262
    Don't want to get too pricey. It's to connect 2 exhaust pipes out of my boiler. The seam is currently sealed with RTV silicone but I wanted an easier/less messy connection. I doubt the pipes will ever get to 500(typical temps are low 300's) but that would be a safeguard in the event a fire starts in the pipes.
  • FestYboy
    Oh that's easy!!! Use fire rope. Small bead of copper seal on the inside and outside edge of the rope for a gap seal between surfaces and slide together. The rope is flexible and good for over 2500*
    High temp pipe coupling ?? Is that what they call it now a days ??
    In my day, we called them Trojans, 50 cents at any truck stop bathroom. Choose your style/size and color. Options baby....options...lol
  • muncybob
    Got a feeling it won't cover the girth Tony.
