SDA mods needed
So I've had a pair of sda 1's for ages and I noticed a driver rattling and figured its obvious the y need a little work. I understand there are mods to improve the sda's and its not something I want to tackle so Im wondering if there maybe someone fairly close to Atlanta ,Ga. that is able to do this for me?
Thanx in advance
    F1nut Posts: 52,000
    A rattling driver could be as simple as loose mounting screws. It could also be a damaged spider or shifted magnet causing voice coil rubbing. If either of the later it's time for a new driver.
    For crossover mods talk to member Westmassguy.
  • Ok, thank you so much
    F1nut Posts: 52,000
    Yes he does, but he doesn't mod those speakers.
  • CGTIII
    CGTIII Posts: 1,249
    If you'd like another ear on it, I'm in metro Atlanta as well. Might help you determine if it's a driver that needs replacing as I've had a few that did.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    F1nut Posts: 52,000
    edited October 2017
