Cable elevators by F1nut
I ordered six of Jesse’s cable supports, and installed them today. At first I thought this would be sufficient to replace my Shunyata supports, but I ended up using both of them. They are being used to elevate my power cables, mostly under the rack, that power the amps, and the source gear. I have three power conditioners, so they each get a cable from the wall, and the amp power conditioners have another power cable to the amp. Essentially, this makes five power cables on the floor.
I ordered these since I felt they were a great cosmetic match with the Denali 2000T amp power conditioners, and they are. Whether the sound is better or not, I can’t really say, but it does look a lot better.
I guess that demonstrates the philosophy of cable deniers who say because we like the appearance of our cables that tricks us into thinking the sound is better is just as wrong as all their other nonsense reasons to deny cables matter.
They certainly are well made, and solid. My Shunyata supports are light weight plastic. The only negative issue for me is that the support opening isn’t quite wide enough for the power cables. However, they would work great for my Shunyata Venom speaker cables in the HT. Still, they do support the cables, just not as snug a fit if the Cable seated better in the support. No complaint here, just an observation, and Jesse did mention they might not be big enough.
Anyway, for those who didn’t take advantage of the offer I can only say it’s your loss. :)
  • vmaxer
    vmaxer Posts: 5,120
    That is beautiful!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • motorhead43026
    motorhead43026 Posts: 4,017
    edited October 2017
    Nicki Minaj would love those black anacondas.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • BlueFox
    BlueFox Posts: 15,250
    Nicki Minaj. Since tonight is this weeks Friday night I will listen to her a bit, with my Anacondas.
    F1nut Posts: 51,886
    Bud, the opening at the top is 15/16". I checked the diameter of your cables, which are supposed to be 1", so I thought they might be a snug fit requiring them to be pressed in a bit. Are your cables larger than 1"?
  • Unknown
    edited October 2017
  • He missed a hair or two, but other than that looks good.
  • BlueFox
    Jesse, I didn’t do any measuring or try pressing them in. They are fine as is, but I will try that tomorrow.
    One of the big benefits of elevating the cables is being able to clean under the rack. It seems every time I post a picture I see dust I missed. :)
    When I was messing around under the rack trying to clean, and put the elevators in, I was listening to the stereo. Then the left amp made a noise, and shut off. Oh oh. Better shut both down, and finish. Fortunately, everything is fine. I would have been P.O.ed if I broke something while doing that. Especially since it was early, and I haven’t had any beer. LOL.
    Clipdat Posts: 13,098
    Serious question, do you think the cables will require a partial "re-break in" process, since they have been moved to install the risers?
    I've heard that if possible you should avoid moving power, speaker, and other interconnects after installing and breaking in, to avoid disrupting the surface of the copper on the wires. Any truth to this?
  • machone
    machone Posts: 1,561
    Yes
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    pitdogg2 Posts: 27,169
    Clipdat wrote: »
    350* oven should bake them in well.....
    nooshinjohn Posts: 25,954
    Clipdat wrote: »
    Bluefox will have the answer... he knows all about tinfoil hat stuff. :p
  • FestYboy
    FestYboy Posts: 3,861
    Russ, that's an antenna...
    East coast Carolina "anti-cable" as a matter of fact
  • lightman1
    lightman1 Posts: 10,797
    Wit some Geetchie magic mixed in.
    txcoastal1 Posts: 13,514
    lightman1 wrote: »
    That's ****$ backwards Sothin' Carolina gerry-riggin' inter-pre-ta
  • PSOVLSK
    PSOVLSK Posts: 5,396
    I got a chance to see these at Skip's and while I can't speak as to whether or not they offer any sonic improvements, I can say they are well made and look very nice. I'd probably buy some just for the looks, but most of my speaker cables are behind the audio racks. Great craftsmanship by Jesse.
    F1nut Posts: 51,886
    Thank you Paul.
    There will be more available in the near future.
  • voltz
    voltz Posts: 5,384
    PSOVLSK wrote: »
    They really did look awesome with the setup Skip had in his upper room with Halen's speakers!
    like a Idiot, I got so lost into the music I never took pics of the up stairs setup :(
    edited October 2017
    voltz wrote: »
    PSOVLSK wrote: »
    Thats when you know the music is GREAT and the gear is AWESOME
  • BlueFox
    I have to admit the cable risers have elevated my system to unprecedented heights, and replaced both Viagra and Rogaine. :)
  • FestYboy
    Always happens when you get new hardwear...
    BlueFox wrote: »
    Well then crap, sign me up for 100 or so.
  • Willow
    Willow Posts: 11,242
    What's that Oreo icecream sandwich looking thing?
    Willow wrote: »
    A shim :p one this is for sure it's not an ice cream sammich
    Viking64 Posts: 7,592
    A shim :p
    Like Bruce Jenner? :p
