Infinity Kappa speakers.
Any opinions on Kappa's ? I was looking at 8's and 9's,but haven't heard them yet. Just asking before I commit.
  • Conradicles
    Conradicles Posts: 6,379
    Fantastic, just make sure you have an amp that can push them.
  • daddyjt
    daddyjt Posts: 3,144
    edited October 2017
    If you can get the Kappa 9 with good polydome drivers, jump on them - anything under $1,200 or so for a set in good shape is a bargain.
    The impedance curve on the bass drivers is pretty demanding on your amp. There is a significant part of the frequency range that is below 2ohms, so make sure you have a stout amp, that's stable at that impedance. Biamping is highly recommended.
    I have a set that I use often, and they sound fabulous - especially on vocals. They were my go-to speakers all the way up to the point I acquired the Legacy Focus 20/30 pair.
    ― Aleksandr Solzhenitsyn
  • dromunds
    dromunds Posts: 10,140
    I have some Kappa 8’s which I’m told are much easier to drive than 9’s. Also have some RSIIIb’s.
    Tony M Posts: 11,732
    I've heard 2 pair.
    Both being driven by Adcom amps.
    Those big Kappa's sounded BEAUTIFUL !!! The bigger the better. But heed what the others have said. You need a great amp to match .
  • Unknown
    edited October 2017
