JBL JBL 608GTI Performance
bossman032
bossman032 Posts: 7
edited November 2004 in Speakers
Hello Guys,
I was wondering if these compare to focals??
How do they perform against its rivals..
anyone ever heard these models they are rather expensive are they worth the $350 bucks..
thanks guys:D
Post edited by bossman032 on
    F1nut Posts: 51,722
    You'd probably have better luck getting answers to car audio questions in the "On The Move" section.
  • bknauss
    bknauss Posts: 1,441
    Expensive and $350 are two different things :)
    Although I've never listened to the JBLs, they aren't exactly known for quality sound. Go with the Focals.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • bossman032
    bossman032 Posts: 7
    haha.
    anyone with heard these personally??:p
  • POLKOHOLIC
    POLKOHOLIC Posts: 407
    Example of a useless post....
  • bknauss
    Not exactly useless. I've heard more than a handful of Focals, and although they're expensive, they're generally pretty good product for the price range. I've heard other lines of JBL component products and they aren't that great, pretty crappy. Even most or all of Team JBL doesn't compete with JBL component products, so that has to raise a couple of questions. I've talked to someone from JBL before, and he suggested JBL non-car products for the front stage. Yet another blow against using their car speakers. Sorry I didn't expand upon my thoughts, but I didn't think it was necessary.
    Brian Knauss
