Stylus tracking force
I finally got some tools to set up my TT, and most are self explanatory, but my tracking force scale just says "see manufacturer specs"... Well the table I have doesn't give that kind of spec, so I submit a question to the forum: what is the typical range of tracking force that you use for your head?
My initial weight before I got the scale was @ .865g (as measured by the scale) so I bumped it to 1.5g as I initially felt the head was too light but wanted to err on the side of caution before getting the scale.
So, recommendations?
Best Answer
  • voltz
    voltz Posts: 5,384
    edited October 2017 Answer ✓
    What Cartridge do you have? my Sumiko Blue point # 2 needs 1.8 grams
    just looking up the spec's for your's and see what it recommends.
Answers
    gudnoyez Posts: 8,172
    Knowing the table and cartridge would help.
    nooshinjohn Posts: 25,955
    The tracking force is determined by the cartridge manufacturer.
  • kharp1
    kharp1 Posts: 3,453
    True to the above, a Google search will probably pull it up.
  • FestYboy
    FestYboy Posts: 3,861
    edited October 2017
    Admittedly it's a POS ION TT, but it has a built in preamp, anti-skate and tracking force adjustment... But it's a start. As far as I can see, there's no spec for their head. I'll look again.
    Ok had to download a PDF... Reading it and find the instructions say 0g tracking force!?? I can't believe that... It'll skip like a bad parolee! So what's a better idea?
    FestYboy wrote: »
    Admittedly it's a POS ION TT.
    Don't take this wrong but if you cherish your vinyl collection don't play it on that. Just saying.
    Agree times infinity and beyond
  • FestYboy
    It's the best thing I have in the house right now :# :'( I have several older pieces but none have any type of adjustment so...
    Can it be that bad if I can adjust head angle, tracking force and anti-skate?? Until I can get the pro-ject carbon I have my eyes (but unfortunately not wallet) on, this will have to do.
    So can I keep things intact till then with the table I have? I can get a better head/stylus for it (but not tone arm) and I have the VDG on the way so that will add table mass... And honestly, of all the tables I have, this sounds the quietest. Just need to dampen the platter with a ring of dynamat (it rings).
    I digress... 0g is too little, so I need a more appropriate number. That's what I'm after.
  • FestYboy
    edited October 2017
    Yes because it was $40 nearly new... And everyone round here wants an arm and/or leg for a decent DUAL or Technics/JVC table (used!!!) I can't get anything that doesn't need work for under 2 bills. And I want to enjoy my vinyl, but don't have the budget for anything new or good used yet...
  • soundfreak1
    soundfreak1 Posts: 3,414
    With the table (arm) you are using it just doesn't matter much! 1 to 1.75 grams will suffice. Until you upgrade (even a little) the difference just won't really matter alot. Not unlike putting 500.00 each Pirelli racing tires on a Toyota tercel, it just won't make a difference.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • dromunds
    dromunds Posts: 10,136
    Like he said. I was gonna say try 1.5 to 1.75
  • dromunds
    Unorthodox disc-washer
    txcoastal1 Posts: 13,514
    I'd come unglued if i walked into my listening room and somebody had one of my records or Cd's or any of my stuff in their mouths
    but DJ Spock in da' house
  • Msabot1
    Msabot1 Posts: 2,098
    FestYboy wrote: »
    A bit of advise from a guy that has been in the vinyl scene since the very early 60's...DO NOT under any circumstances spin your records on that table...Put up your records till you have enough coin to afford one that will not do damage..Playing them on the one you have will be as if you have mounted a roofing nail on the head and expected something wonderful to happen...ain't gonna happen dude...If ya want to enjoy your vinyl in the future..save your coin..purchase something decent that will treat your LP investment like a baby...
  • FestYboy
    Ok, so a member has PMed me and kindly offered up one of his tables for a very good price (I have to hold off for a few paychecks). In light of that, and absolutely NOT to knock the AT cart that's installed, since the stylus is the arguably most important component (the only thing actually touching the playing surface of the vinyl), what should I save my pennies for?
  • soundfreak1
    Depends on how many penny's and what TT it will be installed on.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • FestYboy
    Pioneer PL-7... Number of pennies won't be known till after April 15... Could be "0" at that point :#
  • Msabot1
    PL7 is a good table if in good shape..Back in the day I ran upper level Shure cartridges on it with excellent results...Keep in mind that is mid 70's production so you should have it checked out...
  • Msabot1
    Another good one of that time period is a PL518...solid performer too..
  • FestYboy
    Understanding all of that, now poses the question if I'm better off waiting till I can get a pro-ject, or sticking with a vintage component and building on it... I have the same problems with my firearms purchases
  • Msabot1
    In my opinion...go with the Pro-Ject..but in the end it's all about what you want to do man..
  • mikeyb128
    mikeyb128 Posts: 2,885
    Nothing wrong with a used project or music hall. I picked up an MMF 7.1 for 300 bucks. That was a 1500$ table in its day. That table sounded so good for the money, it was my gateway drug to vinyl. I also had a MMF 5.1SE that was silly good. That one was a 300 bucker as well. For not a lot of coin you can buy a nice sounding table.
    I'm a huge fan of music hall stuff (uses all project parts). They are very good for the money.
    2 channel:
    Theater:
  • There are good deals out there if you are patient. Or save your pennies and go modern. I purchased this vintage SL1350 for $110.00.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • Msabot1
    Wasn't that model one of the last multi changers?...Memory is a bit fuzzy on that one...
  • You are correct. There was one more that followed this, the SL1650.
