HDMI AWG?
Kingkwas
What does an AWG rating have to do with a HDMI cable?
Problem shooting my Apple TV 4K HDR. Can get 4K resolution but not HDR. Think all my other components are 4K/ HDR compatible.
Thank you.
Thank you.
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
R: Def Tech
DVD: Oppo UDP 203
I think the HDMI cable needs to be version 2.0 to be compatible with HDR. And soon it will need to be version 2.1 (48 kb/sec.) to be compatible with Dynamic HDR. (Yes, I know. That sounds redundant.) And also 8K, which will be here sooner than you might think. Not to mention some of the high color gamut stuff. I'll let them sort all of that out before I start upgrading.
And back to your original question, I don't think wire gauge comes into play just yet, but it will with 2.1. -
For HDMI cables they're usually 23-26 gauge wire for the conductors. Longer run cables are usually 23awg. Not all HDR is created equal amongst the brands. Something might not be talking the same language.
Some HDMI cables are directional2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
The difference between 1.4 and 2.0 was hardware/firmware/software related, not cable related. The requirements for cables didn't change a bit. If you are having an issue with components that are not talking to each other properly and are supposedly capable of the latest and greatest offerings, then you are most likely a firmware update away from the two pieces working together fully.
With that said, all things being equal in construction of the cables, I always go with the larger gauge cabling if flexibility of said cable is good.
https://www.digitaltrends.com/home-theater/hdmi-2-0-explained/HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
