5.1 rear speakers for LS90 mains
I find myself moving in a few weeks and have to revisit my home theatre set up. I have been running a mostly built in system for the last decade with LC265i's for the front, LC80i's rear, CS400i center and PSW350 sub powered by Sunfire Theatre Grand III pre and a Cinema Grand Signature for power. There will be no built-ins at the new house, so going back to my LS90's for main with the same amplification and the same sub. I can use either the CS400i or a CSI5 for center. The question becomes what to use for the rear set? I just bought a pair of RTA12's to replace RTI6's on another system as mains. Should I use the RTI6 for rears, go with something new, or pick up some LS50's I've seen used? Space doesn't really matter. I am looking for sound quality. Thanks, Chris
LS90,RTA12, LC265i, LC80i, LC60i, CS400i, CSI5, PSW350, Monitor4a series2
Theatre Grand III, Cinema Grand Signature, B&O TX-2, A few more I can't remember
And I really want my Monitor 4's back that I blew the Peerless tweeters out of several times because I got tired of blowing fuses and put bigger ones in. It was the Eighties.
  • dromunds
    dromunds Posts: 10,126
    Do a search for LS 90 and you will find lots of threads discussing rears
    txcoastal1 Posts: 13,513
    I'd just use the RTi6's that you have
  • rooftop59
    rooftop59 Posts: 8,121
    txcoastal1 wrote: »
    I agree. I don't think that there is enough going on in the surrounds to warrant matching speakers. But if you must, LS/FX are the matching surrounds (there are no matching standard bookies). They come up on eBay pretty regularly, or at least they used to...
    If you want bookshelfs, then the closest match would be the RTi25s I think...
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59 wrote: »
    txcoastal1 wrote: »
    @ZLTFUL had some LS/FX's for sale awhile back. Not sure if he ever sold them.
  • Thanks for the suggestions guys. I've seen some LS50s locally at $80 for the pair. I am really tempted. Not sure of the cabinet condition, but I just refinished my oak LS90s so I'm sure I can handle it. Now to deal with my cat mangled grills. Also found a couple of tiny surround punctures and am going to try the bicycle patch vulcanizing solution. This is a great forum.
  • DollarDave
    DollarDave Posts: 2,575
    For 80 bucks, grab the ls50s.
  • ken brydson
    ken brydson Posts: 9,004
    edited September 2017
    mncad wrote: »
    I run LS50's in the rear with LS/fx' on the sides. Sounds outstanding...
    Post edited by ken brydson on
  • skrol
    skrol Posts: 3,452
    You could go with the LS50 or if you want a bookshelf speaker, the S4, S6 or S8 should blend well. I have a CS250s that blends real nice with my S8's and quite well with my RTA11TL's with RDO198 tweeters.
    Stan
    Main 2ch:
    HT:
    Other stuff:
