New system set up
Hi everyone. I am new here and don't know too much about setting up audio system. I would like to get and advice on setting up sound system for my outdoor patio area. I was thinking buying Denon AVRS730H with Polk Audio RC80i speakers, but not sure how it would sound? I choose them because i read the reviews and it seems that they are decent products individually but not sure if they would work well together. My patio area is 15'X60' and there is a pool adjacent. I can only install ceiling mount speakers. I want it to be loud and with bass but not sure if i can get that with what i choose. I am also not sure how many speakers to get. I am not trying to break the bank either. I appreciate any advice you guys can give me.
Answers
    Viking64 Posts: 7,621
    I am not sure if those speakers would deliver the kind of bass you want. Maybe adding one (or more) of these might be helpful? https://www.polkaudio.com/products/atrium-sub10
  • any ceiling mount speaker with bass?
    Just listen to some old "Yes". Chris Squire was a great bass player.
  • mrloren
    mrloren Posts: 2,474
    In-Ceiling speakers are not going to last long outdoors. They don't have much bass to them either. I would look more at these https://www.polkaudio.com/products/atrium8-sdi mount them to the ceiling. If for some reason you don't like them it's just a couple of screw holes to patch, with in-ceiling you'll have some big holes.
  • dolbyd
    dolbyd Posts: 430
    I agree with the Atrium route. I use 3 Atruim8's for my back Patio. they have plenty bass for being outdoors. You can always wire for a Sub if not enough for you.
    I use an Emotiva 2 channel amp with a Niles speaker selector for 8ohm stability.
    I have an Airport express for control. I have also used Sonos with this setup. pqbq0uosb5o3.jpeg
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
