"Borrow" your Anthem ARC mic
EndersShadow
So apparently Windows Vista, 7, 8 or 10 wont recognize the mic that came with the MRX-X00 series (300, 500, 700).
I have a MRX-500 and full ARC kit. I did use to have a Windows XP machine, but it bit the dust and I replaced it with a better Windows 10 machine....
But now I cant re calibrate my system without the "new" Anthem mic. I'm waiting to get a quote on one from my local dealer, but was wondering if anyone out there had one of the newer mics that they wouldn't mind sending me so I could calibrate my system after moving things around.
If you have one, drop me a PM.
When I went from XP to 10 my adapter would not work, could it just be the adapter?HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
I contacted Anthem directly and the error I was getting was solely related to the Microphone not being recognized as being plugged in. I was able to open ARC just fine, and the Keyspan serial to USB adapter worked perfectly, triggering the ARC calibration screen on my Anthem.
I had re-installed ARC, verified I had the correct version of the software, uninstalled and reinstalled the USB Drivers, tried about 5 different USB cables, none of which worked. So I emailed them
This was their verbatim response:This is a problem with Windows versions newer than Vista and our older microphones. Your options are to try and use a computer with Vista or XP to run ARC, or we could sell you a new microphone that will work with Windows 10. For whatever reason newer versions of windows can’t properly install the drivers from the older microphones.
If you would like to order a new microphone they are $109 + shipping. Part# 2080000283
These can be ordered at a local dealer or by contacting our parts desk directly."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Universal compatibility...... -
I have one that came with my MRX 300 you can borrow....pm me if you need it.HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
That will likely have the same issue as mine given it's the same series AVR, so it will be the same series mic too I would think
Will any of these work?
https://www.google.com/search?q=hello+kitty+microphone&safe=off&rlz=1CASMAG_enUS705US705&source=lnms&tbm=isch&sa=X&ved=0ahUKEwigyqnk5-vVAhUKMSYKHVlqBVgQ_AUICygC&biw=1280&bih=660My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I have a
Mini DSP UMIK-1
Dunno if it will work with your software/OS combo thoMy New Year's resolution is 3840 × 2160
I'm confused...I did my setup with a windows 10 laptop...I think.....
Or did I still have XP......?
The madness!!!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
The madness!!!
Try to run a sweep with it on Windows 10 for giggles...
Mikey081057 wrote: »I have a
Mini DSP UMIK-1
It won't
. I have one of those two. "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Sorry, I only have the old one from my MRX300HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Hey Dan, I've got one from the 510, the next generation compared to yours. Unfortunately I don't have one from the absolute newest one.
Let me know if that'll work for you. -
EndersShadow wrote: »
I'll try and pull the box out of storage in the next day or so.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Can you get your hands on VMware Workstation? Or might be a trial you can use to setup an XP VM. Not sure how it will work since it's ultimately going through Win10, but if it's only a matter of software/driver functionality, it'd get you XP.I disabled signatures.
