"Borrow" your Anthem ARC mic
So apparently Windows Vista, 7, 8 or 10 wont recognize the mic that came with the MRX-X00 series (300, 500, 700).
I have a MRX-500 and full ARC kit. I did use to have a Windows XP machine, but it bit the dust and I replaced it with a better Windows 10 machine....
But now I cant re calibrate my system without the "new" Anthem mic. I'm waiting to get a quote on one from my local dealer, but was wondering if anyone out there had one of the newer mics that they wouldn't mind sending me so I could calibrate my system after moving things around.
If you have one, drop me a PM.
  • gwh
    gwh Posts: 1,451
    When I went from XP to 10 my adapter would not work, could it just be the adapter?
    HT:
    Martin Logan Motion 40
    Martin Logan Motion 50XT
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Def Tech Reference Sub
    Yamaha RX-A3070
    Signal Cable speaker wires & interconnects.
    EndersShadow Posts: 17,704
    edited August 2017
    gwh wrote: »
    I contacted Anthem directly and the error I was getting was solely related to the Microphone not being recognized as being plugged in. I was able to open ARC just fine, and the Keyspan serial to USB adapter worked perfectly, triggering the ARC calibration screen on my Anthem.
    I had re-installed ARC, verified I had the correct version of the software, uninstalled and reinstalled the USB Drivers, tried about 5 different USB cables, none of which worked. So I emailed them :smile:
    This was their verbatim response:
    This is a problem with Windows versions newer than Vista and our older microphones. Your options are to try and use a computer with Vista or XP to run ARC, or we could sell you a new microphone that will work with Windows 10. For whatever reason newer versions of windows can’t properly install the drivers from the older microphones.
    If you would like to order a new microphone they are $109 + shipping. Part# 2080000283
    These can be ordered at a local dealer or by contacting our parts desk directly.
  • lightman1
    lightman1 Posts: 10,796
    Universal compatibility......
  • gwh
    gwh Posts: 1,451
    I have one that came with my MRX 300 you can borrow....pm me if you need it.
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
    gwh wrote: »
    That will likely have the same issue as mine given it's the same series AVR, so it will be the same series mic too I would think
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • Mikey081057
    I have a
    Mini DSP UMIK-1
    Dunno if it will work with your software/OS combo tho
  • mrbiron
    mrbiron Posts: 5,721
    I'm confused...I did my setup with a windows 10 laptop...I think.....
    Or did I still have XP......?
    The madness!!!
    mrbiron wrote: »
    The madness!!!
    Try to run a sweep with it on Windows 10 for giggles...
    I have a
    Mini DSP UMIK-1
    It won't :(. I have one of those two.
  • Sorry, I only have the old one from my MRX300
  • andrew82
    andrew82 Posts: 144
    Hey Dan, I've got one from the 510, the next generation compared to yours. Unfortunately I don't have one from the absolute newest one.
    Let me know if that'll work for you.
  • mrbiron
    mrbiron wrote: »
    The madness!!!
    I'll try and pull the box out of storage in the next day or so.
    msg Posts: 10,452
    Can you get your hands on VMware Workstation? Or might be a trial you can use to setup an XP VM. Not sure how it will work since it's ultimately going through Win10, but if it's only a matter of software/driver functionality, it'd get you XP.
