Tweaks that didn't work
2
  • lightman1lightman1 Posts: 10,497
    edited August 2017
    txcoastal1 wrote: »
    lightman1 wrote: »
    Black socks have a better mids control without shaving off the highs. YMMV of course.
    No No...common since
    Black sox produce blacker back ground,,,pffft,
    buy them books and all they do is burn them
    But...I wear Gold Toe Black socks per Skips suggestion. I see your point on the blacker background....but what good is that without proper control of said mids.
    As to my books...I have colored all of them, every page thank you very much!
    BTW doofus.....it's common sense.....
    Talk about not reading a book or two...... :*
  • BlueFoxBlueFox Posts: 12,180
    voltz wrote: »
    Changing into a clean pair of socks! - I thought it would help clean up the sound but no luck.td2mcydziqzh.jpg
    I bet it did clean up the odor. :)
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    To espound further, most "tweaks" have worked for me. Spiked speakers, wall treatments, power conditioning, etc.....
    About the only thing I have never heard a difference in is cables.......... :o :o B)
    I keeed!
    It's a shell game. One set of IC sounds bomb-diggity on brand X transport but sounds thin on brand Y....go figure.
    Not many tweak failures here. But subtle differences heard.
  • pitdogg2pitdogg2 Posts: 14,689
    lightman1 wrote: »
    I keeed!
    Cables suck blueteeth is where it's at baby
    edited August 2017
    What's your address, Ivan? I'll drive up there and throw all your gear in the yard.....
  • mhardy6647mhardy6647 Posts: 23,404
    lightman1 wrote: »
    txcoastal1 wrote: »
    lightman1 wrote: »
    lightman1 wrote: »
    Did you forget its being held hostage?
    Cu next Tuesday
    lightman1 wrote: »
    txcoastal1 wrote: »
    lightman1 wrote: »
    Dangit! Doc is on to me and my choice of attire whilst listening to the Pet Shop Boys.....
  • halenhalen Posts: 473
    Hey hey. I found my thrills on blue berry hills. Whilst listening to pet shop boys. Magic on fire.
  • jeremymarcinkojeremymarcinko Posts: 3,494
    edited August 2017
    SACD.
    Jk.
  • DSkipDSkip Posts: 16,209
    SACD.
    Jk.
    Actually, yeah and I'm not jk. The format is fine, there was just zilch for a millennial to listen to.
    SACD is a tweak? LOL. I guess it can fall into that category. :)
    Lumin X1
    Sony XA-5400ES SACD
    BlueFox wrote: »
    Not really but it came up and didn't work for me. :)
    It's the same old truism. It is the mastering that makes the recording. Not the format.
    Lumin X1
    Sony XA-5400ES SACD
    BlueFox wrote: »
    Or the fact that a title is even available on said format.
  • Touché. Nah my thing with SACD was for two channel the difference from red book was just ehh. Multichannel though was very nice.
  • F1nutF1nut Posts: 42,948
    Plenty on SACD for me and a good mastering sounds even better on it than it does on CD.
    edited August 2017
    Oh it's better for sure. On a good recording and my equipment it's just the difference of fine wine and damn good wine. To Skips point; I just have so much more content from red book that SACD wasn't worth the journey.
  • Biamping an AVR, duh.
  • schwarcwschwarcw Posts: 7,208
    Any opinions on MQA and/or Tidal "Masters"?
    Carl
  • EndersShadowEndersShadow Posts: 16,895
    @lightman1 told me liquor would make the music sound better. He lied.
    It made it sound fuzzy and blurry.
    And he randomly asked me if I wanted to go camping. Not sure what that had to do with anything...
    The actual ONLY one I have used that haven't seen much difference from is adding the little blocks of rubber with cork in the middle between my gear.
    This isnt to say it CANT, maybe just my gear isnt to a high enough level to require or take advantage of it.
    I still like them mainly as spacers for airflow for my gear, and to keep it from getting scratched....
    Danny, try dynamat instead. The blocks will absorb the transfer of vibrations from the rack/stand to the component, but it won't do anything for the vibrations on the chassis of the component. Weight on top or dynamat will do a better job of eliminating the physical resonance introduced to your music.
    edited August 2017
    DSkip wrote: »
    Not sure where I'd apply the dynamat.
    Downstairs, Xbox One is my digital source, and I really dont want to open it up. Denon is my pre-amp and again not sure if I wanna crack that one open (but I might). My main concern there is heat building around the HDMI board causing caps to dry out and fry the board.
    B&K runs hot and the heatsinks are not setup to allow it either...
    So that systems is kinda fubar'd....
    Loft setup is Roku (so small I'm sure there isnt any space for it) for my digital source, and then the Anthem MRX-500 is the preamp.... That one I might crack open to apply it to it...
    But again, not sure what vibrations I'd be getting since there aren't really any spinny discs to create vibrations, or have them negatively affect the sound...
    Thoughts?
    From a weight perspective, the Xbox is on top my stack on one side in the HT, the B&K is in its own section, and teh Denon is in its own cubby.
    The loft has the Roku somewhat squished between shelves, but the Anthem is free floating on just the shelf....
    Vibrations come from the music brother. Those sound waves transfer the energy to anything they hit.
    DSkip wrote: »
    Point taken. I now have more to ponder lol....
    If you treat the component, the vibrations from the rack are almost moot since the component would be absorbing those vibrations anyways. *ALMOST moot. Different plinths under my components was much less noticeable when I dynamatted them all, but there still was a subtle difference.
    DSkip wrote: »
    We may have to chat further via phone about this sometime....
    I'd honestly be more tempted to play with it in the loft as I really wanna maximize those Ushers up there.... They are just so danged sweet and sexy!
  • voltz wrote: »
    Black socks, white socks, gold toe and what not. I think the obvious visual here is that the socks are not "toed" in properly. Fix that and your sweet spot should open right up.
    Ok, it's late and I've read way too many posts and felt a need to comment somewhere.
    Carry on.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
    edited August 2017
    halen wrote: »
    (for whatever reason, my wife passionately dislikes Bruce's interpretation of Blueberry Hill. ) :/
Howdy, Stranger!
