looking for EPI woofer
One of the 8' woofers on my EPI M-201 died and right now I dropped in an 8'' Radio Shack temp speaker w/ buyl surround. Human speakers still make them but want $60 per and $14 shipping which is worse than Parts Express. Their model is called pro 001. I'd like to avoid going that route. All I can tell you they are 8" woofers w/ butyl surrounds and the square Alnico magnets. I'd settle w/ a foam model. Any of you dudes have any EPI stuff closeted away ? Oh I already checked E-BAY and not a raw speaker in sight. On AK they deleted my post because it should of been in the Barter Town section.
Check out the link .It gives good views of the speakers themselves, parts list,costs and schematics.
http://www.humanspeakers.com/e/epi201.htm
  • skrol
    skrol Posts: 3,456
    You might look for an EPI speaker that used the same woofer (ie. M100). If you can get it cheap, it can be a donor.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • leftwinger57
    leftwinger57 Posts: 2,917
    That's the same speakers I got at a thrift store for $13. Problem was the second I showed them to the dudes over at AK they instantly said they were not original .Sure enough they were Radio Shack drop ins and then I got the originals off E- Bay that needed a foam job ,sent them off to Dave and eventually sold them after some months w/ them. 100v use the same driver .they are not rare but I'm not paying top $ just for one driver.
  • leftwinger57
    never mind one just opened up new for w/ shipping for $56.Ordered it already so my Quite the bargain compared to what Haman Speakers wanted w/ insane shipping charges.
    msg Posts: 10,452
    Yeah, but aren't the Human drivers rubber surround?
    Is the driver you ordered one of the early EPI rubber surround ones, or another foam surround one?
