Hangover Cure
Kinda like I am right now... ROFL...Originally posted by amulford
... just laughed at me...More later,
Tour...
Vox Copuli
The best hangover cure is a bag or two of 1000mla NACL 0.9% IV (Normal saline - intravenous).
I have used this with great success, basically a hangover is dehydration at a cellular level. Alcohol inhibits the secretion of AHD (an anti diuretic hormone) which put simply means the body can not keep its natural fluid balance, you piss it all out, not just what you drink but the fluid from the intra and extracellular compartments.
Some say drink some water before going to bed but that will just fill your bladder up, while the booze is in your system the body can not hold onto the water you put in, in the morning you can drink heaps but it takes a while to be digested and absorbed and to settle accross the fluid compartments to where it needs to be. By having intravenous fluid administration it goes directly where it needs to be, you feel better within 5 minutes.....
Go to a med center and pay for it, it is a 'medical' problem there fore can be treated medically and man does it work well, of course if you know someone in the trade that can do it for you all the better!!!!!
:cool: -
Brody, I'm sure you've never tried this yourself, right?
Well....er..... um..... I plead the fifth on that one:p
