Monitor 10 gasket
Getting ready to mod a pair of Monitor 10s, and noticed that one of these is not like the others. There is no trace of the fourth gasket.
I guess weather-stripping or some other foam tape is the best replacement. Does Polk offer an OEM gasket replacement?
    F1nut Posts: 52,009
    Not unless you buy a new driver. In your case some Armacell or the like will get the job done.
  • jdjohn
    jdjohn Posts: 3,384
    Thanks, Jesse. Will search out Armacell or equivalent. Interesting how the problem-child driver has the extra stickers on it :/
    This will be my second pair of M10 upgrades. Looking forward to getting them back into circulation for another couple of decades.
    F1nut Posts: 52,009
    I can't read the stickers, what do they say?
  • jdjohn
    jdjohn Posts: 3,384
    The other three only have the one big circular sticker.
    F1nut Posts: 52,009
    Is 12771 the serial number on one of your speakers?
  • jdjohn
    jdjohn Posts: 3,384
    Don't think so. Sticker numbers on the back-side of the xover plates are 96XXX and 99XXX.
    F1nut Posts: 52,009
    Hmmm.......you got a strange one.
  • skrol
    skrol Posts: 3,464
    Which Armacell is recommended. All I have found is rather thick. Is there a thin Armacell?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jdjohn
    jdjohn Posts: 3,384
    Look for Armacell tape. I'm seeing some on Amazon that is 1/8in (3mm) thick. It's 2in wide, so will have to be cut lengthwise. Hopefully 30ft will be enough...good grief. Maybe we should do a group buy :D
    pitdogg2 Posts: 27,335
    Home depot has it in stock in the plumbing dept. if you have one close
  • skrol
    skrol Posts: 3,464
    Ok, I guess I was looking at weather stripping. I'll check plumbing.
    Stan
    Main 2ch:
    HT:
    Other stuff:
