Audioquest NRG-2 power cables - I have 2 versions???
jolson72
Hi, can anyone help here.... Can't find information online. I have two different Audioquest NRG-2 power cables. One is much thicker than the other. Both are AQ NRG-2. Both have an RF stopper on the cable. Why is one much thicker? Any ideas?
http://www.audioquest.com/power-cables/nrg-2
call and ask audioquest show them a picture. One could be fake unless you know for sure they are not. -
I emailed them the photo. I have two that are thin, and one that is fatter. Waiting to hear back from them. Thought maybe someone would know.
thin one might of been first gen. They then went to counter spiral wire that could explain the larger diameter. Then again they may just have more filler to keep wires apart. Audioquest is very receptive they will get back to you.
probably just a older and revised version of the cable.Cambridge Azur 651A
Polk LSi M703
Sonos Connect -
Got a message back from Audioquest. They said the same cable. Trying to make the newer versions more flexible, hence the thinner material.
