digital converters
Willow
Is there such thing yet that will switch from a dig coax to optical. the reason is I need to run from my dig cable box a coax but only have optical plugs left. My receiver is the rxv 540 only has one dig coax, my dvd player marantz 4200 only has dig coax...my second dvd player used as cd player only is a toshiba which has optical and coax. so I am stuck !! I need to run the dig coax from the dig box an somehow run it into an optical.....
help please and thanks
Post edited by Willow on
just use a Y adapter to put 2 of the coax cables into the same input. Just make sure that only one of the coax equipped pieces of equipment is turned on at the same timeBob Mayo, on the keyboards. Bob Mayo.
http://www.bswusa.com/prod_item.asp?item=DMM100
I have purchased from BSW and they are real cool. Give them a call.
HBomb***WAREMTAE*** -
HBomb
Very cool item, but $239.... A Y adapter will be no more than $20Bob Mayo, on the keyboards. Bob Mayo. -
Help me understand how splitting a dig coax turns it into light?
I would not recommend spitting digital without balancing due to the jitter that would result. Slight variation in impdance would kill ya.
and how would I balance.
the Y adapter is an intersting way never thought of that. but Hbomb believes it may harm. in which way ?
so you do not suggest this if I only use one at a time -
Willow I thought you need coax to tos link??? what am I missing here?
By using a Y with 75Ohm coax will most definetly change the impedance of the runs.
HBomb
I only have toslink inputs left but If I can share the 1 dig coax input on my receiver .....and by changing impedance what would this do...even if only one at a time isused -
you get many reflections within the cable that carries the pcm to the decoder which will cause jitter, signal attenuation and the likes. This will make your music sound like shite. Thats why they make balanced devices like the one I provided in the link.
It looks like you guys figured out what I meant by using the Y adapter. I was only suggesting a possibly method. I don't know about stuff like the jitter issue.
I'd still give the Y adapter a try. If it works, and you don't notice a problem in sound, then there you go, that's your solution. But if it gives lousy performance, then you'll need to try something else.Bob Mayo, on the keyboards. Bob Mayo. -
Best Regards, Cliff
Originally posted by TheGrayGhost
Coax to Toslink Converter
http://www.altex.com/product_info.php?cPath=24_141&products_id=2411
Well smack my **** and call my Shirley!!! There you go bud, and it's only $25. 3 Cheers for TheGrayGhost!!!Bob Mayo, on the keyboards. Bob Mayo. -
I wonder how it sounds? Probably good imo... Thanks for the link.
they sell them at ratshack too
thanks for the info and links
Much apprecaited
JF -
I was just in rat shack yesterday and they had one (optical/coax) for $15.
they are 50$ CAD here
Much apprecaited
JF
Google is your friend.
Best Regards, Cliff -
this forum is my friend
I bought that coax to toslink converter from ratshack and it works very well I now have dig cable.....and our cable CO has all channels from 1-99 digital !!!! yipeee it makes a difference in the sound much cleaner ,clear and louder....the receiver is turned down to -60dbls for normal watching.
