MagniFi Mini - HDMI ARC - does power up when TV turned on
haler
I have a MagniFi Mini connected to a Panasonic Viera TV via HDMI ARC
Everything is working except for the sound bar turning back on when I turn the TV on.
When I turn the TV off, the sound bar turns off. However when I turn the TV on, I have to then turn the sound bar on as well.
Is there a way to make this work?
Answers
I have the same question. Any response from Polk?
Let me check with Polk's CS guys and I'll post it.
I have the same issue. Not all the time, but most the time. Also same connection as the OP.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Hello,
I'm working with Polk's CS department and they've asked me to find out if you are programming the remote or are you using HDMI-CEC/ARC? If so, what brand of TV do you have?
Regards, Ken
To add to Ken's question, has the Mini been added to the network via the Google Home App for any firmware updates?
FYI, I went ahead and purchased a MagniFi Mini and connected it via HDMI ARC port on my Sony NSX-32GT1. It has been working flawlessly. Turning my TV on and off via the remote also turns my MagniFi Mini on and off. My TV remote also controls the volume, so no universal remote nonsense to deal with.
I'll add this is the only product I could find that both fit a 32" TV and had HDMI ARC. It looks great, integrates seamlessly with my TV, and sounds absolutely fantastic. -
same problem here!!! ARC won't power on the magnifi mini... only power off!!!
what is the solution for that? -
Has it been added to your network via Google Home App?
