RTI Vs Signature
rajatkumar28
hello friends, for the first time in my life I am planning to invest in AVR and 5.1 speakers. Need your valuable advise for setting up my Home theatre.
QUESTION 1
as per my room size ( 13 feet by 11 feet) I have homed on to two options
option 1
RTI A4
CSI A4
FXI A4
PSW 125
option 2
S 50
S 30
S 15
PSW 125
please suggest which out of the two is a better option.
QUESTION 2
which AVR will support these speakers better
Denon 1300w or Yamaha 581
Please suggest and help me out.
QUESTION 1
option 1
RTI A4
CSI A4
FXI A4
PSW 125
option 2
S 50
S 30
S 15
PSW 125
QUESTION 2
Option 2 will will sound better in my opinion.
Would go with the Yamaha myself. Aventage series would be better sounding, but will cost more. -
Although I'm generally a Yamaha fan, at that level, I kind of like the Denon.
BTW, there is no RTI A4. Did you mean the RTI A5 towers? If so, that kind of evens things up. For mostly HT use, I'm of the opinion that the RTiA speakers are slightly better. The FXi will definitely be better performing surrounds. You'll probably be able to find a better deal on the older series speakers. -
Either speaker option will do just fine for both HT and music.
It never hurts to err on the side of the newer offering.
Excellent deals here:
https://www.adorama.com/pkults10a.html?sdtid=10198536&emailprice=t&utm_medium=Affiliate&utm_source=rflaid62905
https://www.adorama.com/pkults20c.html?sdtid=10198536&emailprice=t&utm_medium=Affiliate&utm_source=rflaid62905
You can do better on the sub but will have to spend more.
For receivers you always want one that has the options/functions that you have to have eg. pream out.
Good luckAMP/Pre Pro: Outlaw 7000x, Marantz AV7703
Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
SUB: Rythmik LV12R x2
Source:OPPO UDP-203 -
Option 2 would be easier for an entry/entry-mid AVR to drive I believe.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I would go for the Sig series hands down, just for the fact that this series is better for music. As far as HT, don't think one would be better than the other.
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm. -
Another vote for Signature series, especially if music is in the plan for use.
I have to ward people away from RTi for music, but mine is but one opinion, and I have an aversion to bright, crunchy sound signatures.I disabled signatures. -
I second what msg said. I had the RTi with a Yamaha 681 and it was too bright for my taste for music but good for HT. The signature series does both well. I would also look at the Yamaha Aventage series as they have preouts so you can add an amp later should you want more power.
http://www.accessories4less.com/make-a-store/item/yamrxa760bl/yamaha-rx-a760-7.2-ch-x-90-watts-networking-a/v-receiver/1.htmlLiving Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
^^^Not all AVENTAGE models have preouts, nor does the one in the link above. IIRC its the 8xx series and above that have preouts, but I would check that because its been a few years since I have been in the market for a AVR.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
jeremymarcinko wrote: »^^^Not all AVENTAGE models have preouts, nor does the one in the link above. IIRC its the 8xx series and above that have preouts, but I would check that because its been a few years since I have been in the market for a AVR.
My bad..I did not read the specs on that model I assumed the whole series did and that was a decent deal.Living Room
Office
rajatkumar28 wrote: »hello friends, for the first time in my life I am planning to invest in AVR and 5.1 speakers. Need your valuable advise for setting up my Home theatre.
QUESTION 1
option 1
RTI A4
CSI A4
FXI A4
PSW 125
option 2
S 50
S 30
S 15
PSW 125
QUESTION 2
If I'm understanding your post correctly this will be for HT use, not music. Therefore, I'll recommend the RTiA series, but you'll need a better AVR and sub regardless.Political Correctness'.........defined
President of Club Polk -
Yeah one would think that would be the case. It's funny it works that way. I have the AVENTAGE 1010 powering a 5 Channel RTI series home theater, which includes the big RTI12's. I have used external amplification for the mains in addition to the 1010 powering the center and surrounds and it was good. However, using the different amps to power the speakers made audible differences and took away the seamless/immersive experience I was wanting. I removed the ext. amp and am letting the 1010 do all of work above 80hz. I am actually impressed with the 1010's ability and unless I get a decent 5 channel amp to power the speakers full range, I see no benefit from using two channel external amp's... for a designated HT anyway. So I guess my point is, it's unfortunate that the lower tier AVR's that could benefit the most from ext. amplification are the one's that do not include the preouts to do so.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Yamaha started putting the Aventage name on some lower end models in the past couple of years, where it was previously reserved for the top end. Pioneer did the same thing with Elite.
