Odyssey Audio Candela Preamp. Slightly modified.
ALL212
$1200 not shipped. Local pickup welcomed and if you're fairly close we'll work a 1/2 way meeting out.
http://www.odysseyaudio.com/products-candela.html
Thinning the herd - don't need two Odyssey Audio pre's.
Original metal cover replaced with walnut. You can use ECC802s's in these but they are too tall with the original cover. Neat cutout provides the space needed and cooling as well.
The only change in this is that I replaced the output coupling caps (originally Sonicap Gen 1's) with Clarity Cap MR caps - same value. I love the Sonicap's but these MR's are wonderful. It was an easy mod. Not sure how Klaus will feel about warranty on this but he'll work something out if there are issues.
Dual outputs and HT bypass on this one. IERC heat sinks will NOT be provided (although they are pictured). Wireworld power cord will NOT be provided but a power cord will be included.
12AU7 tubes x2 will be provided. Probably a matched pair of RCA clear tops. Other pairs available for discussion and additional cost.
Aaron
Enabler Extraordinaire
Sweet, I have one of these as well, love it.
Good luck with the sale.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Remote.... it has a remote volume control. Remote does not control inputs or outputs.Aaron
Enabler Extraordinaire -
Location?
NM, saw N.Illinois in Carver threadBeach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Dat's me! Rockford, IL. Come on down and sit a spell...Aaron
