Need three to eight good shielded power cables
afterburnt
Hope to get the job done at fifty bucks a piece average. Where should I be looking, mostly short and flexible. No used, l want to be the first to abuse them.
3-8 ? Not sure whats in your system ? lol
All the same ? What length ? Buy used and you'll get more cable for the buck. 50 clams even used isn't going to buy much.HT SYSTEM-
lsi 9's -
Here is a place that is reasonable - Cullen Cable.
http://www.cullencable.com/
I have seen satisfied owners of his power cables here and on other blogs. I have one set of speaker cables and a Neutrik Speakon SDA cable I made using his cable. I am satisfied.
I believe he will negotiate for a group of cables.
Harry"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
I just put an order for a few Cullen gold power cables in and Patrick is great to deal with. He will knock a few bucks off but don't think he will go that low. You can try pangea ac14se, a little over $50 depending on length on amazon, I run a couple of these and good bang for buck or signal magic power cord, again a little over 50 depending on length.
Good suggestions, only a 50 isn't going to get a new Cullen power cord, and Pangea is pretty stiff and thick.
Re-think exactly what ya need. A good PC will benefit you on source components and amps. If your willing to spend 50 on 8 of them, spend 100 on 4. Your smaller digital devices can wait.HT SYSTEM-
lsi 9's -
Bruce, I just happen to have 8 of these PS Audio ones, BNIB. $49ea if you go with package deal.
Took this one out just to show you a photo of the shielding.
I know that dark spot probably looks like burnt on stromboli cheese, but I assure you it's not.
I disabled signatures. -
Look kinda Cheezy to me.. -
Tony Iwas thinking amps first preamp second and transports last. The total number of cables would be determined by what I hear. 14se is what I think I saw at Audio Advisor. -
You have a lot of stuff AB. Ever consider sell some of it and adding the 4-500 dollars you would have to spend on power cables and getting a statement piece?
I may have what you are looking for. What lengths do you need? Just reconfigured things so I have some extra Pangea 14SE MKII cables. 2x2m, 1x1.5m and 1x1m. Let me know if you might be interested and we can go from there. These are less than a year old and I have the original packaging.2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Never mind I saw you didn't want used. My bad.2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Pre: Anthem AVM90
Amps: Buckeye NC502
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
These are not considered "audiophile" but their construction is sound and the price is reasonable.
http://www.middleatlantic.com/products/power/power-accessories/signalsafe-iec-power-cords.aspx
http://www.middleatlantic.com/-/media/middleatlantic/documents/techdocs/iec power cords_96-01081/96_01081iec.ashxMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
rednedtugent wrote: »You have a lot of stuff AB. Ever consider sell some of it and adding the 4-500 dollars you would have to spend on power cables and getting a statement piece?
What should I get? Most of the spare stuff will be put back in service. -
Here is a page from Middle Atlantic Products document about "Optimized Power Distribution and Grounding for Audio, Video and Electronic Systems".
Their Signal Safe cords are very good at rejecting AC magnetic fields.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
what are your goals w/ the power cords?
If it is "better" sound...
if you
"What should I get? Most of the spare stuff will be put back in service."
o.k. then. just a thought. -
@rednedtugent of course better sound is important but the Dayens didn't come with power cords so I figured it's time to start getting some good ones.
Most of the stuff is going to be put back in service in a few years lol but I am curious. What would be your statement piece? -
That is a good question.
They won't make a difference, Bruce.
Price sheet? -
rednedtugent wrote: »That is a good question.
I like to close my eyes when listening to music, with those I would have to. first for the ugly factor second for I will never have food again factor. -
Which good power cables that don't make a difference do you like. Wireworlds look very Flexible and the Pangea ones say the are for source components. I want a matched set for my monos and my pre. What power cables do you folks run and which ones do you like the best for making no difference?
I have Pangea and Wireworld and to be honest I'm not crazy about either of them but they're all entry level. The flat WW PCs do weird things because they're only flexible in 2 out of 4 directions but in those 2 directions they're maybe a bit more flexible than the Pangea.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I don't like signal cable (thanks @voltz) or PS Audio.
Venom and Sigma from Shuntyata get good press.
I have found the Venom's to make a significant difference on my DAC. I just used the lower end $99 cable. A/B testing with my friends we could pick it out every time.Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra -
afterburnt wrote: »These are not considered "audiophile" but their construction is sound and the price is reasonable.
Price sheet?
The prices are on the first link.
Example: IEC12x4 = four 12" long cables for $62.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I have 3 STRATUS 7 POWER CONDITIONING CORDS! on the way for my 3 Dayens pieces (Sorry for yelling, I have been frozen since the sixties) I think they are really for source components. What do I need to use for high current stuff? Also I guess some of my junk is just 2 pole like a TV cord, what is them be called?
Those are called c7 power cords (figure 8). Pangea makes a 14se c7 and cullen cable c7 are very good.
