There's a thing in my house
mhardy6647
-- a new-to-me thing.
It's very, very dense.
Very.
Dense.
Here is a bottom view.
DSC_8306 by Mark Hardy, on Flickr
and a bottom/side view.
DSC_8309 by Mark Hardy, on Flickr
Further details as events warrant.
It'll be a while -- this is a project*.
* Not a Pro-Ject (just to be clear).
Very.
Dense.
DSC_8306 by Mark Hardy, on Flickrand a bottom/side view.
DSC_8309 by Mark Hardy, on FlickrFurther details as events warrant.
YOU TEASE!
DOC there is a nasty little spider near your Spider!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
yes, the arachnid-type spider has been -- dealt with.
Doesn't look like a DAC to me.
Three 20 amp circuits. -
Verily.
(I need to post an "in use" DAC photo -- it's been a little nutty 'round the ol' Hardy household latterly)
bigger.
and there are two of them.
in one box.
one very dense box.
First!
(in line to buy the Doc Hardy speakers)
Hmmm...it's a speaker....screwed to a piece of pine....with a DENSE 10lb rock on it for stabilization.
What is lemon zester!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Butt shakers for the front porch swing? Tractor speakers? Brown sound generator?
Dual 12 inch coaxes in one box? Cripes...I was thinkin ten inch at most...but a dozen inches....sweet! (Apologies, I like a bit of detective work!)
Bigger.
Based on appearances, I would think this thing is brown-note-compliant.
Oh, and mrbiron, it is (to the best of my knowledge) 100% rock free.
it not a rock on it, it is
a certain phono amp 2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Much work remains to be done -- right now, we're looking at two beefy 15" dual VC drivers mounted in an -- interesting -- configuration in a massive MDF prototype box.
... but the thing certainly looks purposeful; I have to think it will be good for something, audio-wise.
Looks like bottom woofer is slot loaded with the floor or a bottom panel?
The bottom woofer fires "up" into the sealed enclosure (it's back side hangs out in the breeze, as the photo shows, albeit none too clearly).
The other woofer fires "out" of the front of the enclosure. You'll have to take my word for now; it's too danged heavy to drag out of its current (temporary) resting place
So then its push pull with bottom woofer slot loaded.Should dig deep.
