I'd like to install a pair of Polk 14 speakers on the Optical Digital Audio Out of my LG6090. I need
an idea for in inexpensive amp that will receive (accept ) the cable with subsequent connection to the speakers. Is there another way to do this. The speakers are 20 watts (2) I believe. I've read about a Digital optical c oAxial Toslink Signal to an Analog Audio Converter .I know this is a cheapee but I've got only one ear and my wife has hearing aids. I'm just trying to hear the shows w/o investing $100's or $1000's
Answers
    txcoastal1 Posts: 13,514
    Look at Peach Tree audio products
  • Jim Shearer
    Jim Shearer Posts: 369
    Since you want the cheapest means to get optical from your TV to a pair of speakers, and aren't concerned with high sound quality, here is one possibility:
    optical converter:
    https://www.parts-express.com/fiio-d03k-coaxial-optical-dac-digital-analog-converter--230-120
    small amp--if 8 wpc into 8 ohms is sufficient:
    https://www.parts-express.com/dayton-audio-dta3116s-class-d-micro-mini-amplifier-2-x-15w--300-3815
    if you need more power, then consider:
    https://www.parts-express.com/dayton-audio-dta-120-class-t-mini-amplifier-60-wpc--300-3800
    Note: both amps use class-T (sub set of class-D) topology, and as such are not compatible with sub-woofers using speaker level connections!
    Best thing to do may be to call Parts Express & talk with one of their advisors to make sure this would work!
    Cheers, Jim
    A day without music is like a day without food.
    tonyb Posts: 33,076
    Cheapest way in my view, grab a receiver off of craigslist that has digital inputs. You can usually find one for 25-50 bucks. Connect the digital output of the tv to the digital input of the receiver, then connect the speakers to the receiver and your done.
  • deronb1
    deronb1 Posts: 5,021
    tonyb wrote: »
    Yup, and if you are not comfortable wuth CL, pawn shops and some check cashing places usually have oodles of em.
