Anti-vibe bases in billet
xschop
I was impressed by the high-impact poly foam on my billet 5JR crossovers and decided to make some better bases for my shop amp and CD that take some abuse...
I cut super thick grooves for fatter O-rings and will glue them directly to bottom frames with Aleens. The glue is now a favorite....
Pretty nice.
Thanks pitt. I didn't go monster on these. I made from spare 2.00" round 6061 T6Don't take experimental gene therapies from known eugenicists.
Wow, very nice. Very clean on the o-rings.
More info on the impressive foam?I disabled signatures. -
Ethylene vinyl acetate foam rubber. I'm using the medium VA yield sheet. It can be found at Grainger or MSC. It's non-conductive as well. The XS-CRS crossovers are getting a layer added directly to board also.Don't take experimental gene therapies from known eugenicists.
