Rotel amp
gwh
Was considering purchasing this amp to run in a three channel config. at a pair of lsi7s and a lsic.
Would this amp be a good match for the lsis?
Is this a good price for this amp?
Thanks,
G
rotel
Thanks,
G
rotel
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
That one isn't going to work for you. The LSi's are 4 ohm speakers and the Rotel when bridged to a 3 channel amp is only rated to drive 8 ohm speakers. Rotel makes a good product and they make a dedicated 3 channel amp, so maybe you'd want to keep a eye out for one of those. Check Audiogon too.Political Correctness'.........defined
President of Club Polk -
Up to $450.
Really looking for a five channel, but I'm considering several options.HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
It's gonna be tough to find any decent amp that will suit what you are looking to do with that budget. $450 pretty much limits you to a stereo amp. What you might think about is the Marantz MA-500 monoblocks. You could get 3 for close that. I was running 5 before I upgraded. They'll do 180 watts into 4 ohms. Not a bad little amp either.Go BIG or go home!
I have that amp. It's a nice amp but probably not appropriate for your speakers. It's power up thump in bridged mode canl make you winch at times.
regards
DaveTime is the best teacher. Unfortunately it kills all its students. -
There are 3 of these amps on ebay right now in Dallas. They would push your LSi7s real nice.
Sometmes you can pick these up seperately as M1s or mounted on a rack together they are called an M3.
Soundstream M1s
Cheers,
DennisHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
As always, I appreciate the info.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
You can get a Harman PA5800 used for about your price range which will drive your surrounds...I am waiting for mine that I got on ebay. It got extremely good reviews for the price and can ddrive 4 ohms at about 110 watts/ch. They are supposed to have that great HK sound....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
i use that amp for my front soundstage. got it for a rediculously cheap price as a floor model at 6th ave electronics. i have 2 of the sections bridged powering rta-12's realized they are 4 ohms and was not too kosher, but it has driven the 4 ohm load for almost 2 years without breaking a sweat. if you can get the amp for a great price, i wouldnt rule it out. i love the amp, and as i said, it drives my 4 ohm load speakers without breaking a sweat.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
regards
Dave
this is true, it does pop like hell at times.Living Room 2 Channel -
