WTB Sonos, Denon or Bluesound power amps!
Looking to add something for the patio area, and I was hoping may be someone here has a Sonos ConnectAmp, Denon HEOS amp or Bluesound Powernode for sale. Thanks.
AVR: DENON X4000
FRONT L/R: ARX A3RX-C
CENTER: ARX A2RX-C
SURROUND L/R: ARX A3
SUBWOOFER: PSA-XV15
SERVER: UNRAID 15TB
MEDIA PLAYERS: DUNE SMART SERIES D1
HDTV: VIZIO M601D-A3R
  • GFOviedo
    GFOviedo Posts: 353
    Sorry. Moderator please move to correct section please.
    AVR: DENON X4000
    CENTER: ARX A2RX-C
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
  • GFOviedo
    GFOviedo Posts: 353
    I've decided to go with a WiFi AVR instead. Cheaper and will do the same job.
    AVR: DENON X4000
    CENTER: ARX A2RX-C
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
    GFOviedo wrote: »
    Yes and no, usually part of what you pay for on those other devices is the software. Which makes them very user friendly. Receivers tend to not have the best apps/software and can get aggravating to use.
    Depends on your needs I guess.
  • GFOviedo
    GFOviedo Posts: 353
    tonyb wrote: »
    GFOviedo wrote: »
    After having owned the Denon HEOS Amp HS2 and nowthe Bluesound PowerNode, I have realized that my Denon X4200 app works much better.
    For some reason or another my PowerNode keeps losing connection. I've spoken with tech support and tried different things to attempt to fix this without any any positive outcome.
    However, my Denon X4200 via WiFi has not issue using the Spotify app.
    AVR: DENON X4000
    CENTER: ARX A2RX-C
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
