Downfiring sub on concrete?
Jimbo18
Jimbo18 Posts: 2,351
I have a small Pioneer 100w downfiring sub that someone is interested in but they want to use it in a garage and put it on a concrete floor. Is the hard surface going to make it to "boomy"?
  • Jstas
    Jstas Posts: 14,994
    It shouldn't.
    If anything, the solid footing would improve response since the floor won't be flexing.
    Expert Moron Extraordinaire
    F1nut Posts: 51,936
    It might as that is a hard reflective surface. They can always put a piece of scrap carpet or the like under it.
  • Jstas
    Jstas Posts: 14,994
    edited May 2017
    Yeah, like @F1nut said, reflections can be a problem. Won't necessarily make it boomy, though. More like shouty, like when a tweeter is real bright.
    A chunk of carpet underneath it will tame all of that. Even just a piece of, like, particle board. Something with a non-smooth surface that will help break up reflections. Carpet would work best, though.
    I have a pretty powerful sub sitting on the concrete floor in the basement. It's on spikes so it's sitting on the concrete but there is a carpeted floor under it. It's only boomy when I set the crossover to make it boomy. Otherwise, the concrete is a positive thing since it can vibrate the entire floor in the living room and gets muddy because of that.
    In the basement, though, the low-end extension actually improved being on the solid surface.
    Post edited by Jstas on
    F1nut Posts: 51,936
    ^ Nailed it ^
  • Jimbo18
    Thanks, guys, he has decided to take the sub. And funny you mention about the carpet, I was thinking the same thing. I have a couple 18"x18" carpet squares laying around and was going to offer him one.
    He said he has a receiver already and a pair of Bose 201's that he's going to use. I would think the Bose would be tough to place well in a garage. Good luck there.
  • [Deleted User]
    [Deleted User] Posts: 342
    edited May 2017
    I saw a headbanger cruising up my local inner city street about a year ago. His car audio system was literally shaking the ground! Luckily he pulled over & I got a chance to ask him about his setup. The boot was full of amps (I counted 6). The subs that were shaking the ground turned out to be a pair of massive 1500 watt MTX subs! The guy had cut holes in the floor of the trunk and had the subs pointed straight toward the ground, with just a perspect cover over them! Not sure if streets in the US are concrete?...but that car sounded pretty good! B)
