Looking for a program to transfer text messages, phone contacts, etc
Does anyone know of a free Windows based software program that will transfer texts, phone contacts, etc from a Galaxy S4 to a Galaxy S5?
SDA SRS 2.3TL's
SDA 2B TL's
  • MrBuhl
    MrBuhl Posts: 2,419
    Have you tried the Samsung Smart Switch app? That's what I used the last two times and it worked great. Phone to phone, just hook em up;
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    Thanks, I'll give that a try, however, I dropped the S4 on the floor and it's really screwed up. Only the upper portion of the display is visible and the phone is opening up all kinds of apps on it's own. I'm buying an S5 today and hopefully I'll be able to do the transfer.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • MrBuhl
    MrBuhl Posts: 2,419
    Good luck! That doesn't sound so promising I'll have to agree!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    VR3 Posts: 29,550
    I dont know about Android, but on my windows phone, I can hop phone to phone with a cloud back up and within thirty minutesit will sync my apps, start screen layout, contacts, text messages, call history, everything. Iy is literally like I never changed phones...
    I would assume Android has a similar function available
    pitdogg2 Posts: 27,331
    Some you can transfer from phone to sd card then transfer back to new phone.
    Just a thought
