B&K EX-442 and ST-202+ Different ??
VSAT88
Wanted to know if anyone here knows the difference between the B&K ST-202+ and the EX-442. Is one superior to the other ? All I could find was a schematic that does not say too much as far as I can see. Both amps are mentioned. I read somewhere that the 442 has two transformers. I know that the 202+ has one. Any help will be appreciated.
Maddeningly, there used to be a great one-sheet on the B&K website comparing all specs for their amplifiers. Very handy. It appears with the sale of the B&K name, that pdf is no longer available. What a shame, wish I had saved it! If anyone did save a copy it would certainly answer your question from a spec standpoint anyway.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
I gots some info. I leave for you to interpret...Jay
Jay, that "Previous Amp Specs.pdf" is the Holy Grail. That is exactly what I was looking for. I had seen it before on some site somewhere and it was not only incomplete but was nearly illegible. That is such a find. Thank you for sharing it. I also left you a PM. Regards, Jim. -
Are you looking at a specific EX-442?
I have one. It was my first amp. It has a single toroidal transformer, four soup can type caps. The one I have is the Sonata version and also has the optional XLR inputs. The heat sink is internal instead of hanging off the back.
That's a great document AG posted with the specs. If accurate, you can see that the EX-442 offers 75A peak current to the 202+'s 28A.I disabled signatures. -
Yes, I saw that. 75 A peak is crazy good I would think for what I would use it for. Two SDA-SRS 2's and yes I do want the B&K. I have one on the line now hopefully to pick up tomorrow.
Previous amp specs.... http://www.radie.us/literature/b_k/Previous Amp Specs.pdf
sorry. did not see agfrost posted.
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Thanks Steve. I am picking it up tomorrow in Atlanta. Both, the EX-442 and the Pro 5 Preamp he has. Wish a country boy luck on his drive thru the big city.
hehe, you ought do fine. Just throw a tarp over the hay bales
excited for you, man. That EX-442 is a nice piece of gear. Versatile. It's still one of my favorite pieces. I have the accompanying MC-101 preamp, and the Pro 5 Pre you're picking up seems similar, though never heard one so not sure of the sound. Should make for a nice 2ch setup. fwiw, I find the MC-101 and EX-442 to be a bit brighter than I typically prefer, but maybe some of this older gear I have is in need of build component refresh. The EX-442 works great with everything else I've used it with. you're in for a treat.
Have you used any high current 200wpc amps before?
I bought the EX when I was trying to tame some RTi10s. I didn't quite manage it to my liking, but man, did it spank those speakers to a level that two high end consumer AVRs I demoed at the time simply couldn't touch. Tight, controlled, authoritative.
So what are your plans, and what are you planning to run this new gear with?I disabled signatures. -
Man I am glad you thought of that..I got to unload them chicken crates before I head off ! I do not think I have ever run any high current equipment besides the HCA-1206 Parasound and if it's not high current then I don't know what high current sounds like. Bridge mono that one is 360w per and it is some kind of powerful. I listen to .FLAC files and some LP's from time to time. Mp 3 too thru my system. As of now it's a PC to a DAC to a Kenwood C2 out to the Basic M2 amp into the re capped and re tweeted..lol..RD-194's..SDA-SRS 2's. I am very happy with the sound but I have wanted American made speakers/amp/pre for a long time. I have a little Dynaco ST 70 and a pair of Dynaco A 25's that also use the same pre (C2) and the rest of the front end equipment that I really love listening too as well. As you can see I am the farthest from an audiophile as they get but I don't think, I know my system sounds great. I will be really happy to get the B&K equipment. I had him test for DC offset and both channels are at or about 25 mA so I should be able to listen for a while until I make up a parts order for a complete re cap. Thanks for all of your help. Have a good one . Going to bed early, gotta get them hogs slopped early so I can hit Atlanta..
^^^ lol
Psssh, not at all, and I'm no one to judge, either. I'm really curious to hear your impressions once you get set up. And obviously no pressure, if you don't like it, it won't hurt my feelings, but I haven't had a B&K piece yet that I haven't enjoyed. Even the little Video 5 amp. I think it's only 105wpc or something like that, but man, so smooth and sweet with the HSU HB-1s, and the VTF-2 picks up the bottom end. I use it with a Parasound Model 7100 for the br system. Be interested to see the rehab progress on this when you start it.
Charlotte says Wilbur is a Wonder Pig.
I want bacon anyway.I disabled signatures. -
exactly!!! I'm gonna save it this time!
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
No way I can say I do not like this amp. Its pretty awesome. Set DC offset and Bias as per B&K paperwork. Runs very nice and cool. More detail than my other amp. Seems like it has a bit more bass and the separation of the channels sounds better. Like the speakers are farther apart or something. Really like it so far. Don't get me wrong it does not stomp on the Kenwood M2 but I think I am going to like it better in the long run. The Kenwood will stay at home where it belongs and will act as a back up amp. when I take this one down to bare boards to do a re cap with new bias and DC offset pots. I got the Pro 5 Pre as well but I have yet to check it over. Running the Kenwood C2 I restored. It will be very hard to beat. Man I really do thank you guys. I can always come here and Polk around a bit and find friendly folks that are willing to help.
