XLR Interconnects
DaveHo
Looking at Signal Cable Silver Resolution or Cullen Cable. I have several other cables from Cullen Cable and am leaning that way. Though I'm tempted by the Signals due to the mere fact I haven't tried silver before. These will go between an Oppo 205 & a Parasound P5. Anything else I should give strong consideration to for $150 or less for a meter pair?
I bought some Aural Harmony Cryo Gold Alloy Sonnet-II
here I believe and like them. I'm going to say they will
give you a smoother sound. -
@DSkip has some wireworld XLR's. I'm using a set of them myself for my MiniDSP to Crown XLS connections."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Good timing on this topic...
I'm looking at the same thing, for the same equipment! -
Went with the the Cullen XLR's. cullencable.com/index.php/products/interconnects/xlr-interconnects
Given my previous experience with some of Patrick's other cables, I expect I'll be happy. -
Furutech cables are good value and well made. They should sell some half decent finished cables at that price point. That said, imho I would check out USA Audio Mart and Audiogon for 2nd hand cables. Providing you buy cables purchased through an authorized dealer, you can get into some nicer wire for the same coin.
Let us know what you think of the Cullins
