Isolation devices, who uses what?
mikeyb128
mikeyb128 Posts: 2,885
edited May 2017 in 2 Channel Audio
A gentleman up here in Canada makes some very nice roller blocks for a decent price. I'm thinking of buying 2 sets of 3 to try under my DAC and pre. I'm using BDR cones right now under my preamp only.
What do people here use? Research shows the roller block method seems to be the most effective, and looks very interesting. Looking
For cost effective devices Under 100 bucks per item. My rack is filled with sand, dynamat on cross bars and under shelves. With thick bamboo boards Under each component.
2 channel:
Theater:
  • mikeyb128
    This is what I'm looking at. 85 bucks Canadian.
    2 channel:
    Theater:
  • mikeyb128
    nbrowser wrote: »
    Used car tires off wheels isolate rather well. :)
    They don't sound so good Ken.
    2 channel:
    Theater:
    pitdogg2 Posts: 27,187
    edited May 2017
    I'm a big believer in the sorbathane pucks. Audioquest use to have the big blue half hemispheres i bought several sets on clearance they're the bomb. Never been a fan boy hard metal ball and puck type seems to me your gear would slide around on them too easily.
    msg Posts: 10,452
    edited May 2017
    Mikey - those are beautifully machined little works of art.
    Curious here, guys - what are we after? Seems like this is a couple vs decouple option? Vibration isolation vs. ?
  • [Deleted User]
    [Deleted User] Posts: 342
    edited May 2017
    I use mostly Stillpoints Ultra 6's + Ultra bases for my heavier components & Stillpoints Ultra mini's under my Oppo dvd player. Stillpoints feet use what they call "technology pockets" comprising a carefully shaped stainless steel body, "Caylx" filled with ceramic balls & a spiked screw which sits in the middle of the ceramic balls. You can read more about it here. The Ultra 6's as you can see in the pic below use 6 technology pockets...hence 'Ultra 6'.
    I'm also not far off ordering a set of these Magico S Pods to spike my S5 Mk2 speakers (see pic below). They're basically a hybrid constrained layer cone/spike design, with the constrained layer being copper.
    I do get why some people prefer wooden 'tuning feet'. I own a set of feet similar to Harmonix tuning feet which I use under my Schumann resonator, though I prefer not to use 'tuning' devices under my main components as I prefer my supports and cables to be essentially neutral. That said, Harmonix tuning feet are cool. So are Shun Mook diamond resonators.
  • mikeyb128
    msg wrote: »
    My understanding is these are isolation type devices, but will also drain vibrations. This is done by converting the energy into a rocking motion.
    2 channel:
    Theater:
    msg Posts: 10,452
    Pretty sure I'd be distracted by the doppler effect that creates.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    This one has been very good over the years.
  • mikeyb128
    That looks more like a "hot box" device to me.
    2 channel:
    Theater:
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2017
    I use Mapleshade Micropoint Brass Footers under electronics.
    http://shop.mapleshadestore.com/Micropoint-Megafeet-set-of-3/productinfo/MPMFSET/
    Now that taxes and vacations are over, I will be ordering some Magico SPODs for the speakers. Unfortunately, Magico hasn't updated their website to show them to the world. But they will sell them. :)
  • @Bud, those things look like mean brass knuckles...not to be messed with!
  • mikeyb128
    I placed an order for 2 sets of roller blocks. I've been moving my black diamond racing cones between preamp and dac (only have one set of 3), I can't believe the difference they make. When moved to different locations under equipment, I'm getting different results as well.
    Plan is to put roller blocks under preamp, and dac. The BDR cones will go under my balanced power conditioner, which is placed on a butcher block, with vibrapod cones under the butcher block on the floor. I will most likely screw the BDR cones permanently to the conditioner.
    Will see how these work before putting them under other pieces of gear.
    Thanks to those who shared their isolation devices.
    2 channel:
    Theater:
  • [Deleted User]
    Thanks for sharing your results so far! B)
  • dannylightning
    dannylightning Posts: 233
    edited May 2017
    a pair of wooden bar stools may not look as nice as real speakers but they are generally pretty sturdy on carpet and get your tweeters pretty close to ear level
    EDIT....
    i thik i posted in the wrong thread.. lol
    Cambridge Azur 651A
    Polk LSi M703
    Sonos Connect
    EDIT....
    Bar stools huh....don't have a thread about bars, stools, or cocktails.....but we use to. Think we lost it in the transition. Started by an old member Russman, it was a sort of "what are you drinking" thread for Friday nights. Maybe it's still around, haven't looked.
  • tonyb wrote: »
    EDIT....
    i was reading a thread about wobbly bookshelf stands on carpet, i went off to do something else and came back here i though i still had that thread open but i was wrong lol.
    i once had some bookshelf up on a set of wooden stools which worked great. it did not look great but to me thats not a big deal, they were nice and stable and i was not worried they would tip over.
    Cambridge Azur 651A
    Polk LSi M703
    Sonos Connect
  • motorhead43026
    motorhead43026 Posts: 4,019
    Barstools don't work well, as I have fallen off many of them. They are very unstable platforms.
    – Kevin Alfred Strom
  • steveinaz
    steveinaz Posts: 19,545
    I have concrete slab, so I don't really use any isolation aside from the spikes on my speaker stands.
  • mikeyb128
    I think I would have problems fitting a bar stool into my rack :blush:
    2 channel:
    Theater:
