Magnifi mini, doesn't turn on when tv turns on
jakek82
I have the Magnifi Mini connected to an LG LM7600 via HDMI and the sound works, soundbar turns off when the tv is turned off. It however doesn't turn on when i turn on the tv. I have to manually turn it on.
Hi jake82, sounds like it is working 50% for you at least. Lucky you!
For me the HDMI ARC connection to my LG with Simplink activated does not work at all. Good luck ... -
Hello,
Contact Polk's CS department at 1-800-377-7655 select option 1 and they'll help solve the problem.
Regards, Ken
