Advice for tippy speaker stands
dromunds
dromunds Posts: 10,098
A friend of mine and his wife bought some bookshelf speakers from me and they have carpet. I tried several different brands of speaker stands and they were both very tippy, one was a Skylan-type filled with shot, the other had a round weighted disc bottom that resembles a smooth free-weight. I suppose the floor under their carpet is not flat or something, but even carpet spikes didn't seem to help, although the spikes on the Skylan-type stands were not adjustable. Any advice for a different approach? I have little experience with carpet but in my limited experience with carpet I've never had a problem with stands especially with spikes. Let me know if more info is needed. thanks in advance for any suggestions.
  • Jimbo18
    Jimbo18 Posts: 2,348
    Heavy granite tile underneath? Flattens out the carpet and stops the rocking, maybe.
    pitdogg2 Posts: 26,933
    Spikes need to get through the carpet into the floor beneath, did they do that? A lot of spikes are too rounded and not pointy enough to make it through both carpet and padding so they end up floating. I had to step on the base to get them into and pass the carpet and padding, but i also tossed the brass set and made my own from steel bolts to get a very sharp long point to work on the thick carpet and padding once.
    Jimbo also makes a valid point sometimes you just need a lot more weight to stabilize the weight up above.
    F1nut Posts: 51,676
    ^ THIS ^
    Also, you have to make sure the spikes are long enough to reach the solid foundation.
  • dromunds
    I believe the spikes that came with the stands may be too rounded and not pointy enough. Where is the place to order better spikes, preferably adjustable ones? Thanks guys.
    F1nut Posts: 51,676
    All spikes are adjustable to one degree or the other. It may involve adding a nut on the threads.
    How thick is the carpet? What is the flooring under the carpet?
  • DaveHo
    DaveHo Posts: 3,582
    I've frequently used the cheap black oxide finished spikes from parts express. Less than $10 for a set. Not pretty, but they are sharp, and not seen anyway.
    F1nut Posts: 51,676
    Here's a nice selection of spikes.
    http://www.adonacorporation.com/tweaks.html
  • dromunds
    Thanks for the help. The carpet is thick with a pad underneath and I assume an old hardwood tongue and groove under it all, as its an older home. I have little experience with spikes but I can see I need to get some sharper longer points. Lol.
    you'll need to know if they are a metric pitch or standard English T.P.I. (threads per inch)
  • arekon
    arekon Posts: 77
    dromunds wrote: »
    A friend of mine and his wife bought some bookshelf speakers from me....
    (CLIPPED)
    Not trying to be sexist here but in 90- something percent of households, the wife or old-lady is not involved or unaware with home audio recon.
    for example in my shack, i either get a 'adda boy' or a 'are you kidding me?'
  • dromunds
    Actually, in this case my friend's wife, who was also my friend in college, so I've known them both for many years, told me she wanted to get her turntable going again so she could play "rekkids." Somebody had taken the cartridge off the headshell and so I put a better cart on and aligned it and then I took a look at their speakers, which had no surrounds left whatsoever, and mentioned that I had some speakers I could move their way. She was up for it and was on cloud nine that she could play vinyl again not to mention the tuner and CD's actually sounded decent. However, she wasn't happy with the tipsy nature of the stands on her carpet so I'm trying to make that all good. She has quite an album collection, well "they" do, but actually she is buying new stuff because her daughter is in three bands in Austin. I give her credit, she likes her music and I'll support that all day long....
  • arekon
    arekon Posts: 77
    ^^ shoot. my fault. didnt mean to make you throw all of that out there... ill take a mulligan, i was being sexist.
  • Nightfall
    Nightfall Posts: 10,084
    What's a Skylan type stand, just out of curiosity?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • dromunds
    Ha, I'll probably have trouble describing this, but it's a pretty substantial metal stand with hollow tubes that have been filled with shot, and a flat metal top. base plate has spikes although as I mentioned the spikes are too round and don't make contact with the floor. I think they are generic stands sort of copied after Skylans or another popular brand. They are solid but tippy on this carpet, I think it's the crummy spikes.
    Nightfall wrote: »
    maybe like these? maybe
    http://www.skylanstands.com/stands.htm
  • dromunds
    Yeah resembling top photo.
    txcoastal1 Posts: 13,499
    Yeah, those with good spikes, especially loaded shouldn't be tippy IMHO
  • pearsall001
    pearsall001 Posts: 5,236
    These plum bob's work great for speaker stands & amp stands...I picked mine up at Home Depot. No trouble at all piercing carpets.
    Never thought about those will file that in the memory banks....
    F1nut Posts: 51,676
    Skylan stands are not metal. The top and bottom plates are MDF and the posts are PVC.
  • dromunds
    The ones I have aren't Skylan they just resemble them in looks sort of, but mine are metal with metal top and base plates. There's no discernible name on them. I got them one time in a deal but never used them. They are substantial and I think using proper spikes they're going to work okay.
