CS150 Timbre match or close enough?
codycatalist
To RTA11TLs? I know the CS250 is considered close enough but mine took a crap (tweeter went out) and found the 150 on my local c list for $25
****EDIT****
I did some research (not easy) and found that someone on this forum used the CS150 with some monitor 10s which I know do have the SL2000. I figure it will be a close enough fit. For $25 it's worth a shot.
****EDIT****
Post edited by codycatalist on
CS150 tweeter is SL4000Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I might try to find a M5 jr with the same tweet, but if you're really tight on cash the 150 is worth a shot, and can certainly function as a temporary fix...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Yeah temporary indeed. I thought of a M5jr as a pair is on c list as well for $50 but my entertainment center doesn't have big enough openings for me to lay it horizontally.Just a dude doing dude-ly things
