CS150 Timbre match or close enough?
codycatalist
codycatalist Posts: 2,661
edited April 2017 in Speakers
To RTA11TLs? I know the CS250 is considered close enough but mine took a crap (tweeter went out) and found the 150 on my local c list for $25
****EDIT****
I did some research (not easy) and found that someone on this forum used the CS150 with some monitor 10s which I know do have the SL2000. I figure it will be a close enough fit. For $25 it's worth a shot.
Post edited by codycatalist on
  • codycatalist
    CS150 tweeter is SL4000
  • rooftop59
    rooftop59 Posts: 8,120
    I might try to find a M5 jr with the same tweet, but if you're really tight on cash the 150 is worth a shot, and can certainly function as a temporary fix...
    Game Room 5.1.4:
    Bedroom 2.1
  • codycatalist
    rooftop59 wrote: »
    Yeah temporary indeed. I thought of a M5jr as a pair is on c list as well for $50 but my entertainment center doesn't have big enough openings for me to lay it horizontally.
