SDA II replacement driver questions
Hello, I recently decided to buy a friends pair of SDA II speakers that he bought in college. He bought them used a couple years old, 30 years ago. I am very familiar with them, as I have been in close contact with him this whole time. They are second generation 2's (horizontal tweeters, 3 6.5 drivers per speaker, no protection fuse on the back).
Anyway, one driver is locked up. He had one driver replaced after maybe 3 or 4 years of owning them, but this is a different one. All drivers are MW 6501's, including the one replaced, but the replacement has a later date on it than the others.
I have ordered a pair of MW 6503's to replace the bad driver, but I'm wondering what the best configuration would be? Basically I have a pair of speakers that need 6 drivers, and what I have are four "matched" 6501's with presumably the same amount of wear/mileage on them, 2 replacement 6503's which I believe are New Old Stock, and one newer 6501.
So, given that assortment of 7 drivers, what would you put where? I understand the 6501 and 6503 have slightly different specs, so the 6503's should probably be used in the same spot on each speaker, but is there a better place to put them (bass, mid, or dimensional driver), or does it not matter?
Thanks for any input.
    F1nut Posts: 51,936
    edited April 2017
    The 6510 is closer to the 6501 than the 6503.
    Regardless, put the two oddball drivers in the SDA position.
  • Are the SDA drivers always toward the outside? Or where are they on the 2's with three drivers?
    F1nut Posts: 51,936
    Always on the outside.
