HT advice: S15s with good sub, or S60s with my current junker?
JiminKY
JiminKY Posts: 6
edited April 2017 in Speakers
So I bailed on the TL1 center, and have the S35 on order. With what I am comfortable spending, right now, I can either add a pair of S15 (maybe S20) bookshelf speakers and an SVS sb12-NSD, or go for the big S60s and keep the 15-year-old Sony HTIB sub I've been making do with (no built in crossover adjustments, etc., but Audessey on my Denon 2112-ci seems to make decent use of it).
I've read people suggest that with stands, there is not much savings in the bookshelf speakers, but I would not need new stands. At about 85% HT use, I'm leaning toward upgrading the sub and going with the bookshelves, but the floor-standers sure look nice.
Post edited by JiminKY on
  • rooftop59
    rooftop59 Posts: 8,120
    Bookies and the sub. Bigger bookies if u can swing it. Your receiver won't open those towers up anyway. And the sub will make a Huge difference for ht.
    Game Room 5.1.4:
    Bedroom 2.1
  • rpf65
    rpf65 Posts: 2,127
    I would probably pick up a pair of S 50's, and start saving for a sub. Either that, get the SB 12-NSD, and save for the S 50's.
    Those 60's may be a little to big a load for the Denon you have.
  • mrloren
    mrloren Posts: 2,473
    Hmm, nice box being opened here,
    I went to Polk and had a listen of the S60 on an old bottom end Onkyo AVR, They sounded amazing. Polk designed the Signature line to be driven with lower power AVR. I have my S60 and S20 being powered by a Marantz SR5010, both systems sound amazing.
    No If I was starting where the OP is I would go with the S15 and a HSU VTF2-MK5. Speaker stands can be costly but can be made easy. Just google DYI Speaker stands. I think IKEA sells some decent ones too for like $75 a pair. Or just use the wall mounts on the S15.
    I would then go into save mode for a pair of S55/S60
  • WLDock
    WLDock Posts: 3,073
    edited April 2017
    Here's a way to save a little...refurb, B-Stock, Open box.
    S30 - $159.99 shipped / refurb
    http://www.ebay.com/itm/Polk-Audio-Signature-S30-BLACK-WALNUT-Center-Channel-Speaker-/361951957532?hash=item544604921c:g:koAAAOSw2gxYweMe
    S15 - $184.92 shipped / Open box
    http://www.ebay.com/itm/Polk-Audio-S15-Open-Box-Bookshelf-Speakers-Pair-/172576096263?hash=item282e564007:g:LT4AAOSw32lYyIa9
    or Auction
    http://www.ebay.com/itm/Polk-Audio-Signature-S15-Bookshelf-Speaker-Pair-Black-/382046270108?hash=item58f3bb729c:g:gMoAAOSwcdRY9Q60
    Rythmik LV12R - $529 shipped / B-Stock http://www.rythmikaudio.com/clearance.html
    $873.91 total
    Then, save up and buy a pair of the towers S50 or S55 down the line when on sale at the Polk ebay store or Adorama. Move the bookies to the rear.
  • sgmsmg
    sgmsmg Posts: 556
    eBay has a 20% coupon deal going on right now for a max of $50 off if that helps.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • rpf65
    rpf65 Posts: 2,127
    The Marantz is a much more capable AVR than the Denon 2112ci.
    Even though it is constantly preached here, just look at watts per channel claims.
    Denon. 90 watts per channel, one channel driven. No load given.
    Marantz 100 watts per channel, 2 channels driven, 8 ohm load, full freq range.
    Polk designed the Signature line to work with budget systems, but I would still say that the S 60's are a little to large of a load for that particular AVR.
    I think that it will be able to drive the S 50's, but I wouldn't advise anybody to go bigger than that with an AVR that small. Would pair better with bookies, but the OP said he prefers floor standers, and nobody here should suggest the S 60's would be a good match with his current gear.
    If the OP really wants the S 60's than the priority should be upgrading the AVR first. Otherwise I stand by my previous recommendation.
  • mrloren
    rpf65 wrote: »
    You are correct, his AVR might not be up to the task.
    When I had my listen at Polk in Vista they had the S60 hooked to a low end Onkyo and it drove them nice. That is what I base my opinion on.
  • JiminKY
    JiminKY Posts: 6
    I appreciate all the input. I'm fine on money, just trying to balance what I want with what I truly need (and now considering what my AVR can handle). The AVR is staying, as I am more than satisfied with it. Of course none of it this stuff seems reasonable to the wife who is happy with the TV speakers (which I can only assume are actually there, having never heard them).
    Before the wife decided we just had to grab an Ethan Allen entertainment console, I was ready to start my upgrades with a new, higher-end SVS sub. But that was going to be the only purchase for a while and I was going to upgrade the other speakers over time. Suddenly, the new configuration required a center less than 4" tall, and my whole world changed! LOL.
    An impulse purchase of the TL1 center was a cheap and easy way to make her feel like she didn't crush my man-cave dreams. However, I quickly realized it was time to re-evaluate and get real. For now, I've gone ahead and ordered the S15 bookies. Was about to pull the trigger on the sub, when I saw the mention of the HSU VTF2-MK5 and Rythmic sub, above. The HSU has good reviews, but I literally did not see anywhere to purchase it online, and the Rythmic seems a bit over my current target budget, even as B-stock.
